Question about Dryers
My dryer tumbles, but the timer doesn't move. and it wont heat... please help with my problem
  • Mark Truitt
    Mark Truitt May 11, 2010
    Could be a number of things. More info please.
  • Sassy6 May 11, 2010
    Can you please supply me with the make and model of the dryer? Open the door and look around the hole where you throw the clothes in and you should see the model number.
    Scholar:
  • 62 Answers
You didnt mention make or model number but by the fault report you gave its most probably the timer unit.
If you would like to email me the details I can possibly find out prices for you.
Regards
aardvark repairs
aardvark.repairs@btinternet.com
Posted on Nov 17, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Tip
I have an electric whirlpool dryer about 4 years old..here are my issues and any...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Nov 30, 2009 | Kenmore 62602 Electric Dryer
Whirlpool tumble dryer awz121 not tumbling clockwise ...
if it tumbles in reverse but not forward then it may be your reversing relay is only working on one side.
Oct 31, 2012 | Dryers
My dryer is 4 years and the heater wont heat up but the tumbler tumbles
First check your dryer vent, make sure that it is venting properly. If that doesn't work then it is your dryer heating elements.
Apr 27, 2011 | Frigidaire Dryers
Dryer wont heat up
There could be a number of reasons why your dryer is not heating.
1) The element may be faulty
2) A thermostat or thermistor could be faulty or need resetting (if you have one with a reset button) You would need to check your hand book for this info.
3) you could have a wiring fault or lose terminal.
4) If you have a dryer with a revers tumble (one that goes in the opposit direction for a few minutes before continueing) on some models this incorperates a revers timer that works off the main timer and when it is in revers tumble the heater is switched off. If the timer is faulty it would keep the heater permanently switched off.
For more Hotpoint help click on link
Mar 18, 2010 | Roper Dryers
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
Model WED5300SQ0 not heating and timer not working
Well with moving it around and all it could have any number of things happened. If it wont tumble, no lights, no heat or anything check that the plug has 240volts to it. then check the wiring going into the dryer may have broke wires or anything like that. but I would check the plug first if it has no power what so ever. If you check the plug and it doesn't have power check the breaker to see if it is tripped.
Sep 03, 2009 | Whirlpool LER5636P Electric Dryer
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Nov 11, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
