Question about GE Profile PSH25MGS Side by Side Refrigerator
Defrosting daily - GE Profile PSH25MGS Side by Side Refrigerator
  • 4,070 Answers
It is normal to defrost every day for 20 minutes or so but the defrost thermostat prevents it from getting too warm.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 17, 2009
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per your DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Sears... (I don't USUALLY recommend for purchase)
http://www.searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Repair-Maintenance/Questions-Answers/location-of-defrost-timer-on-sears-fridg/Model-59665932402/0582/0161000/338616?modelNumber=59665932402
also see other .com retailers
partsselect,
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
Frigidaire refrigerator/freezer
bit confuse with your problem.. are you having a defrost issue or leaking issue? If defrost issue... Check your compressor it is working? compressor - The thing that make noise behind the refrigerator...
Sep 05, 2007 | Refrigerators
My lg fridge is not getting cold only the freezer is getting cold
There may be frost blockage, due to failure of frost timer. You need to call company service person.
Feb 18, 2017 | LG Refrigerators
Why is my refrigerator leaking out the front almost daily?
You have a blocked defrost drain. You will have to remove the back panel and pour hot water around the drain trough and defrost the drain. Once water flows through the drain then you can reassemble the freezer and you should be good to go.
Aug 01, 2014 | Kenmore Refrigerators
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Freezer goes up 20 deg. for two hrs. ? DAILY.
The unit is sticking on defrost....you will need to replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Freezer thaws and refreezes daily
The would be a problem with the defrost sticking and staying on too long...change the defrost timer/control board out....
the defrost cycle is making the freezer warm and then it goes off and the freezer refreezes...
most times it fails the other way and does not work at all but sometimes this happens...
Howto Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is not defrosting properly, and water is pooling under the fridge daily. In fact, water congregates in the bottom of the freezer side. What doesn't escape to below the fridge, freezes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer keeps icing up, warming down the fridge
Good day,
Step one is get your money back. He fixed nothing. He obviously did not check everything.
You have an issue with the defrost system.
The defrost system which melts excess frost off the coils daily, has had a failure.
It is made up of 3 components. The defrost control, defrost thermostat, and the main defrost heater. You will need a qualified tech to isolate the bad part and replace it. If you want to perform the work yourself and have a VOM meter, post back to me.
Jun 15, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
My admiral refridgerator ia aproximately 20 years old.It makes a popping noise almost daily,usually at night.What is this ?
The popping noise is water evaporating or dripping on the defrost coil its a heating element that defrosts the freezer section with a heat coil like in your oven on a smaller scale.
Mar 08, 2010 | Admiral AAV7000A
GE Profile PSH25MGS Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
