Question about Nintendo Wii Console
The Wii powers up, but the TV says that it is unable to detect a signal.
  • emolinari Nov 17, 2009
    Thanks..but I wish it was that easy of a problem. The Wii console shows power green but even if I remove tbe AVI cable, the TV doesnt see a difference. Hopefully its the cable and not the ports on the TV.
  • 3 Answers
Try making sure your Audio/Video cables are connected to the television and the other end is connected correctly into the Wii. If you have a flat screen, make sure you are on the right Input setting.
Posted on Nov 16, 2009
No signal to tv from wii
I hope that what I am pretty sure is wrong (hardware failure)is not your problem.
1) Try hooking it up to another TV
2)Check physical connections: cables, and inputs on both TV, and wii. Lose and dirty connections are usually the problem.
3) You stated you unpluged everything. Did you wait ten minutes before plugging bower back in? Be sure output is what it is suppose to be using multi-meter.
4)Nintendo has software(code) embedded so that pirated software is always detected and blue screens the unit. There are geeks that have "workarounds" with SD cards, but I have found OEM games used in pawn shops for as little as $5 most for no more than $ 20. My point is if you used a copied game Unit is fried. I am on my 3rd wii, the 1st one when they first came out lasted 3yrs but had a ton of hrs, on it. The second I bought used for $100 at a pawn shop lasted almost 2 years, and the current one, used is almost 2yrs. old. paid $160 but got about 10 games and wireless controllers, new cables.
I hope your problem is just a connection or power adapter.
Nov 07, 2013 | Video Game Consoles & Games
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
Cant get it to connect
First start by powering off the wii console. Then unplug both your router and modem and plug them back in after 10 seconds. Give the router and modem about one minute to fully boot up then restart the wii. If you are still unable to connect, make sure your wii is set to automatic detection and not manual.
This should fix your problem, I hope I helped
May 16, 2011 | Nintendo Wii Console
Plug wii in and turn on and get nothing. the tv
If it isn't turning on the power cable probably needs to be reset. Unplug the power cable from your Wii and the wall and let it rest for 10-15 minutes. It sounds silly, but try it. Nintendo built in a reset mechanism for power adapter failures.
Jan 24, 2010 | Nintendo Wii Console
There is power to the console. We can hear the
Check the input cables coming from the Wii to the TV. Then check to see that your selecting that right Aux channel. On most remotes there is a source or input selection. Pressing this should cycle through all input channel selections. One input should be the Wii signal.
Bret
1-2-1ComputerServices
Oct 06, 2009 | Nintendo Wii Console
Black Screen Wii
Nintendo support or repairer would be your best hope, as it does sound like a low level brick.
Aug 10, 2009 | Nintendo Wii Console
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Europran wii
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
  1. Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
  2. European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
  3. European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
  1. You need to get games from France (or at least Europe)
    You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
  2. You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
  3. Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores.
    If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
Hope that helps...
Apr 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
