Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
Engine knocking what would a faulty crank shaft sensor cause
    Sergeant:
    Champion:
  • 225 Answers
It would not start or start hard.
Posted on Dec 29, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a knock sensor code on my 99 mitsubishi
If you have the turbocharger pushing too much air into the engine, you'll run the chance of a piston, piston rod or crank shaft fail. This will cause catastrophic internal damage to your engine. The knock sensor tells the computer this and then adjusts the engine to prevent it.
Oct 10, 2014 | 1999 Mitsubishi Diamante
Where is the 2nd crank shaft sensor located, and is there a diagram to show where these sensors are located?
is it a no crank or crank no start?
Possible causes for code P0335
- Faulty crankshaft position sensor
- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery
Read more: http://engine-codes.com/p0335.html#ixzz3Cxw6SN6O
Sep 10, 2014 | 2004 Buick Rendezvous
Car doesn't start after replacing both knock sensors
The car should start without the knock sensors, why would you change the knock sensors? They are a piezo quartz generator that rarely go bad. Usually other symptoms of engine faults produce a code that say there is a knock sensor problem. Back to the no start thing, maybe you may have caused a unrelated problem. Bad reconnection or something. Retract your steps to see if you did something wrong
Dec 31, 2013 | 1992 Toyota Camry V6
Po325 code on 97 nissan maxima
P0325 NISSAN - Knock Sensor Circuit Malfunction
Possible causes- Faulty knock sensor
- Knock sensor circuit short to ground
- Knock sensor circuit short to power
- Knock sensor circuit open
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0325_nissan.html#ixzz29K4BM3th
Oct 14, 2012 | Cars & Trucks
What is code 325
P0325 - Knock Sensor Circuit Malfunction
- Faulty Engine Control Module (very unlikely).
P0139 - O2 Sensor Circuit Slow Response Bank 1 Sensor 2
Possible causes- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Rear Heated Oxygen Sensor Bank 1
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
Sep 27, 2012 | 2000 Mercury Villager
I have a 2002 Jeep Grand Cherokee. I am getting a bad crank shaft sensor/misfire error code. I have replaced the crank shaft sensor, spark plugs and coil but the problem stiil remains. What else could...
Your engine will also have a Camshaft position sensor too (P0340). This can sometimes make the Crankshaft sensor code come on (P0335). Your misfire could be down to a low oil level or faulty knock sensor. You have ruled out the possibility of it being a spark related issue. Hope this helps...
Mar 10, 2011 | 2002 Jeep Grand Cherokee
05 kia amanti with diagnostics codes p0350,p0320,p0300,p0302,p0303,p0304,p0305,p0306.skipping at times.when it does skip & misfire the rpm gauge goes crazy.this problem is not consitant
Generic OBD II Diagnostic Trouble Codes
DTC CODES P0300 to P0399
P0300....Random/Multiple Cylinder Misfire Detected
P0301....Cylinder 1 Misfire Detected
P0302....Cylinder 2 Misfire Detected
P0303....Cylinder 3 Misfire Detected
P0304....Cylinder 4 Misfire Detected
P0305....Cylinder 5 Misfire Detected
P0306....Cylinder 6 Misfire Detected
P0307....Cylinder 7 Misfire Detected
P0308....Cylinder 8 Misfire Detected
P0309....Cylinder 9 Misfire Detected
P0310....Cylinder 10....Misfire Detected
P0311....Cylinder 11 Misfire Detected
P0312....Cylinder 12 Misfire Detected
P0313....Misfire Detected with Low Fuel
P0314....Single Cylinder Misfire (Cylinder not Specified)
P0320....Ignition/Distributor Engine Speed Input Circuit
P0321....Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322....Ignition/Distributor Engine Speed Input Circuit No Signal
P0323....Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324....Knock Control System Error
P0325....Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326....Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327....Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328....Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329....Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330....Knock Sensor 2 Circuit (Bank 2)
P0331....Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332....Knock Sensor 2 Circuit Low Input (Bank 2)
P0333....Knock Sensor 2 Circuit High Input (Bank 2)
P0334....Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335....Crankshaft Position Sensor A Circuit
P0336....Crankshaft Position Sensor A Circuit Range/Performance
P0337....Crankshaft Position Sensor A Circuit Low Input
P0338....Crankshaft Position Sensor A Circuit High Input
P0339....Crankshaft Position Sensor A Circuit Intermittent
P0340....Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor 'A' Circuit Range/Performance (Bank 1 or Single Sensor)
P0342....Camshaft Position Sensor 'A' Circuit Low Input (Bank 1 or Single Sensor)
P0343....Camshaft Position Sensor 'A' Circuit High Input (Bank 1 or Single Sensor)
P0344....Camshaft Position Sensor 'A' Circuit Intermittent (Bank 1 or Single Sensor)
P0345....Camshaft Position Sensor 'A' Circuit (Bank 2)
P0346....Camshaft Position Sensor 'A' Circuit Range/Performance (Bank 2)
P0347....Camshaft Position Sensor 'A' Circuit Low Input (Bank 2)
P0348....Camshaft Position Sensor 'A' Circuit High Input (Bank 2)
P0349....Camshaft Position Sensor 'A' Circuit Intermittent (Bank 2)
P0350....Ignition Coil Primary/Secondary Circuit
Nov 17, 2010 | Kia Amanti Cars & Trucks
1997 breeze is shooting codes 12 46 43 55
OBD Code 12 - No Distributor Reference Pulse (Diagnostic Test Active) The Engine Control Module-ECM uses the distributor reference pulse to calculate the engine speed. On newer engines, the Crank Shaft Position Sensor performs this function.
Symptoms:
  • When flashing the Check Engine Light to read codes, code 12 will always display first, indicating the diagnostic system is active
  • The engine will not run with a "hard" code 12 set
Common Problems:
  • Chances are you will never need to diagnose a code 12. Rather, the problem would be a crank, no-start condition.
  • If code 12 does not flash, that would indicate a communication problem with the ECM.
  • Code 12 does not show when reading codes with a scan tool. If there is a communication problem, the scan tool will let you know.
OBD Code 46 - Pass-Key II System Error - Circuit out of Frequency Range The ECM receives a signal from the Pass-Key module. When the correct signal is received, the ECM will allow the engine to start and run. Please review the RepairPal article on the GM Pass-Key Anti-theft systems for more information.
Symptoms:
  • Engine may not start
Common Problems:
  • Faulty ignition lock cylinder
OBD Code 43 - Knock Sensor error The ECM receives a signal from the Knock Sensor based on the amount of engine ping detected. The ECM uses information from this sensor to help calculate fuel delivery and spark timing.
Symptoms:
  • Engine ping
  • Lack of power
Common Problems:
  • Faulty Knock sensor
  • Poor connection at Knock sensor
OBD Code 55 - End Test.
Hope ehit help (remember comment and rated this).
Jul 22, 2010 | 1997 Plymouth Breeze
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
102 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
