Question about Ryobi Garden
Pull cord loose - Ryobi Garden
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Rewind spring either broke or is gummed up.
Posted on Nov 17, 2009
Loose cord
Recoil spring may be getting old and stretching, but more than likely, your pull cord is old and it has become stretched. Try replacing pull cord first.
Apr 12, 2013 | Briggs & Stratton Garden
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Dec 08, 2011 | Briggs & Stratton Power Products 5,550...
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
Replace starter cord
Undo the screws holding the housing of the starter cord & remove the whole thing.
Before continuing it may be wise to take a picture of the pulley & how its held on so you can put it together correctly.
Inside you should see a removable clip attached to a moving nylon peg thing, remove this, then a washer, then remove the round plastic pulley that holds the cord.
Remove the old cord.
Thread one end of the new cord (ensure it's the same thickness) from the outside of the pulley through the hole so it comes out in the middle as it was before.
Tie a knot in it, trim off any eccess cord & pull it back through, tucking the knot neatly into the place where the knot goes.
Wrap the cord 3 or 4 times round the pulley & thread the loose end through the hole in the housing.
Put the pulley back in the housing as it came off & replace the washer, peg & clip.
Pull the cord to make sure it springs back ok.
***Now pull the chord right out & slowly let the spring pull it back in. Now thread your pull handle on right up to the housing, put a knot in it a bit further than this point so the spring holds the handle tight to the housing and its not dangling loose.DONT CUT THE ECCESS OFF YET
Ensure youre happy with the length of cord when its pulled out
If its too short, undo the knot, leave the pulley in place, use a thin screwdriver to pull the cord into the housing to wrap it round the pulley one more time (theres normally a notch cut out of the pulley to get the cord round between the pulley & housing)
Now repeat from ***
Now screw the housing back in place.
It's easier to do than write!!!!
Sep 13, 2011 | Garden
Power cord is loose, power cuts off
If its the Auto wind cord then fault could bre internal contacts, not easy to get into suggest best to go to service centre.....
Oct 10, 2009 | Miele s558 Silver Moon Vacuum
How do you replace the pull cord that broke?
On a lawnmower, you just remove the top housing (side for tillers and other lawn equipment). Knot one end of the cord and put it in the slot in the wheel. Make sure when you wind it that the wheel will turn when you pull the cord. If it won't turn, wind the other direction. After winding feed the loose end thru the hole in the housing and replace the housing. Attach the loose end to your handle, cutting off any excess.
Sep 28, 2009 | Garden
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Starter cord loose on Bolens 4.5 HP lawn mower
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
May 12, 2009 | Garden
2001 Honda Prelude Hood Pull Cord
you are going to have to fiddle to get a hand inside the grill to release the latch.  This may require a mechanic.
Mar 25, 2009 | 2001 Honda Prelude
Garden Logo
44 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
