Question about Garden
Vacuum to blower
How do you convert it from a vacuum to blower?
  • Garry Clelland May 11, 2010
    make and model please
  • 2712 Answers
SOURCE: Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Posted on Aug 27, 2008
chad7houston
  • 62 Answers
SOURCE: Black & Decker Blower Vacuum Mulcher 1 Ea Nosie Problem
Sorry. No way to fix this problem. If you have a small yard, electric blowers are the TOPS! I have both, and while the gas blower can go places the electric one can't, I like the electric one FAR better! It is MUCH quieter, and sooooo much lighter, and to top it all off, it blows faster!!! All of this, and better for the environment.
Hope this helps!!
chad
Posted on Oct 08, 2008
kachbibi1
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
  • 449 Answers
SOURCE: using leaf vacuum as snow blower?
yes
Posted on Feb 06, 2009
SOURCE: turning the vacuum on.. paramount pb350
That blower vacuum is very easy to operate if you have all the pieces. You need the tubes to blow, you need the larger tub to vacuum and if you want also a bag to attach to the bigger tube. The bigger tube has to be attached at the opposite part of the machine and once you turn it on it will vacuum.
Posted on Jun 11, 2009
I have an older b and d leaf blower , i need to find out what makes the proplellar turn a different way , to go from vacuum to leaf blower ? tks it a b and d bv 2500 type 3
If your blower is not manufactured to be convertible you won't be able to make it into a vacuum. The turbine will not withstand the force of the debris entering it and will be destroyed quickly and could even come apart forcefully injuring you and others around you.
Now if it is designed for vacuuming, the air intake will have a cover that can be opened and allow for the vacuum tube attachment to be connected there. The turbines on these types of blowers are made of materials that can withstand the debris that will be flowing through it and some even have a metal blade that grinds the debris before it enters the turbine then the debris will flow through the outlet tube where the air flows through that blows the leaves and into a bag or filter top that connects to a trash can. Now if this is something that you just have to do and the blower you have isn't a vacuum it can be done but use EXTREME caution. And some pretty major modifications will have to be done to the frame and body of the blower. Some blowers have safety switch's that will prevent the motor or engine from running if any modification is made or if debris is entering the turbine so be prepared for these. I recommend not doing this.
Nov 20, 2016 | Garden
How do you get it to vacuum?
If you got all the parts you will find an adapter that fits over the air intake system for the blower. That is the vacuum source.
Jul 05, 2013 | Poulan Pro BVM200VS 25CC Gas Leaf Blower...
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
How do I convert from blower to vac
First, remove the blower tube. Then connect the collection bag on the blower tube outelt. Then open the bottom fan cover. Keep it open and connect the vacuum tube into the opening.
Dec 05, 2010 | Craftsman 225 Mph Electric Blower Vac
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
How do you convert the vacum to a blower?
Im guessing ... remove the device you are vaccuming with and put it on the other end of the air stream. Is yours both a vacuum and a blower???
Oct 18, 2009 | Garden
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Oct 25, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Vacuum or Blower?
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
