Question about Nokia 2600
MENU SCREEN AT THE TOP G WITH A RELINE GOING THOUGH IT.
Cant log in
Hi I have two solutions hopefully one of them will help you out. The first solution is if you forgot you password. What you are going to want to do is insert your Mac OSX Install disk into the computer and then restart the computer. As soon as the computer restarts hold down the "option" key until a menu appears asking you what you want to boot up with, select the disk. It might take a while to load from the disk but once you are there it will look like you are trying to reinstall Mac OSX but if you go to the top menu bar there will be a option to reset the password of a user. All you simply have to do is enter the new password that you would like to use for your account.
For my second solution, sadly you would have to reinstall Mac OSX, currently there is no way to bypass the login screen if a failure such as the computer not letting you log in even though you are certain that your password is correct. In order to do this you are simply going to want to follow my steps in the previous solution but just follow the on screen instructions on the screen.
I hope this helps, Justin
Jan 28, 2011 | Intel Computers & Internet
N0 inst with new toshiba 19bv500b to operate usb-and-mp3how do ido it on screen im going nuts HELP RAY
In the digital channels area press menu and go to the lowest option and it should be that one.
This is just off the top of my head though.
Sep 15, 2010 | Televison & Video
U400 LG R on the screen
it stands for Roaming - which you may or may not be doing. (ie. mountain areas get sketchy reception and will access whichever tower is closest, which subsequently leads to being termed as "roaming" even though you should still be within your area code range). you should be able to get it off by going through your menu options to the display settings and choosing to not have notification when you are "roaming".
Mar 19, 2010 | LG U400 Cellular Phone
How do you reline a Ryobi es30
Here is a link to homelite and ryobi. but you will need trimmer # like ry30023 or something like that. it should be on the trimmer. when you find your trimmer look at the manuals.
https://www.gardnerinc.com/recons/disclaimer-lg.php
Hope this helps
Tobaz
Jun 16, 2009 | Ryobi Garden
Cracked screen will not allow me to move from screen to screen. I can get to main menu but screen will not allow me to press and move to next screen/menu.
This unit can be repair only by the manufacture or a 3rd party that repairs them, They will put in a new touch screen the cost may be more then you can get a new unit for due to GPS pricing going way down.
thanks for your free question
Rulds2008
Apr 29, 2009 | Garmin nuvi 200W GPS
Screen keeps going to menu mode
THE SWITCH BEHIND THE MENU BUTTON ON THE TV IS MOST LIKLY DOING YOU IN
Nov 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Full screen
What games do you play?
In some internet games you can press F11 for full screen.
Though in most games you have to go through their menu's to get full screen.
In windows the default keystroke for fullscreen in Alt, Enter pressed together.
Though that is not a guarantee either.
Generally how to get full-screen is different from game to game in some sort of settings menu.
For instance I play Last Chaos online and it is automatically full-screen.
When I played runescape online I had to select full-screen at the log in screen.
Sep 17, 2008 | HP Pavilion dv6000z Notebook
Out of control!
try going into the setup menue and revert back to default settings might do the trick.
Mar 11, 2008 | Archos 605 WiFi Digital Media Player
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Nokia 2600 Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
