Question about Kenmore 22422 Top Load Washer
Water won't shut off in washer - Kenmore 22422 Top Load Washer
  • 464 Answers
Here is a test, turn the machine on to fill and pull the plug, if the water keeps coming into the machine you need to replace the water inlet valve where the hot and cold hoses attach to your machine.
Posted on Nov 17, 2009
110.18522790 washer have to turn off supply lines or it keeps dripping water into the washer
The inlet water solenoids need to be replaced. Appliance parts houses will have them.
Sep 14, 2017 | Kenmore Washing Machines
Jen air dish washer not shutting water
Open the door to the dishwasher. there should be a circular peice on the left or right side of the tub. it maybe stuck. if its stuck. the water won't shut-off.
May 28, 2012 | Jenn-Air Dishwashers
Lavamat problems
Most likely, your washer's fill valve is leaking. You can probably find replacement valves. I found the AEG LAV1480 parts at several sites.
If your water pipes to the washer have shut-off valves where the hoses connect, turn the water to off after doing the wash. If they don't have shut off valves, have them installed. It's a cheap way to avoid floods when either the valve or the hoses fail. There are some high-end electronic shut-off valves that include a timer so you won't forget to turn off the water. Two simple 1/4 turn shut-off valve (one for hot, one for cold) are cheaper but you have to turn off the water after you finish the load.
To test the shut-off valves when in the closed position, disconnect the hoses from the washer and put a bucket under them. No water should flow into the bucket beyond the water that was initially in the hoses.
I hope this helps.
Apr 29, 2012 | AEG Washing Machines
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | GE WDSR2080D Top Load Washer
Over filling
Hi
Thanks
Rylee
Sep 06, 2010 | Kenmore 24032\24036 Top Load Washer
Wont stop filling up. It will overflow with water
Hi
Thanks
Rylee
Aug 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Kenmore 22422 Top Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
