Question about Sharp R-1480 Microwave Oven
I have a Sharp R-1450 and am trying to take it out but don't have the paperwork ou how it was mounterd. Any suggestions. In the dark in GA
  • 670 Answers
Hello, I am assuming this is a microhood above the range. This link will take you to Sharp website and a viewable set of installation instructions. The model number may be different but most will install with these.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Posted on Nov 17, 2009
Trying to remove sharp r-1480, removed two bolts on top, don't know where the other bolts are holding unit in.
there are 2 scews behind grill piece that runs above the door and control panel. loosen and you'll be in business..
Aug 06, 2011 | Sharp R-1480 Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
My 1450 blew the in-line 20amp fuse, just
sounds like the H.V. diode,capacitor,or mag is shorted first 2 items are cheap, the mag gets pricey, call "Appliance Parts Pro's" they can help you on parts great prices and fast shipping
Jul 27, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
How do I uninstall an old Sharp R-1450 Carousel over the stove microvave oven? I removed the screws from the top that it hangs on and it still won't move. Help and Thanks.
You need to remove the grill above the door to find two more screws that go straight to the back wall plate. They will be on the left and right side. That is the only other way that they mount to the wall.
Good Luck
Dec 18, 2008 | Sharp R-1480 Microwave Oven
Model R-1450 Microwave Oven
Does it have a "Custom Help" pad on the keypad?
If so, try pressing that and following the menu prompts. You may need to hit Custom Help then 1.
If not, you may have to unplug it for a minute, plug it back in, then try again.
(I don't have the owner's manual for this oen)
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Sharp R-202EW Microwave Oven
Sharp R-1450 micro over range removal
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Sharp R-202EW Microwave Oven
SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Mar 06, 2008 | Sharp R-202EW Microwave Oven
Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
Jun 04, 2007 | Sharp R-202EW Microwave Oven
Sharp R-1480 Microwave Oven Logo
510 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
