Question about Cell Phones
I can't connect my cellular phone to the computer
I initially use opera in browsing then i change the memory card and resend the opera which i was using before yet it can browse
Internet access via cellular provider is more and more popular, but the cellular Internet plans offered by many providers are expensive. There are a few alternatives to cellular Internet plans, including using your mobile phone as a modem. This process is called "tethering" and allows you to connect to the Internet through a dial-up connection in your phone. With the right equipment and technique, you can use your LG Vu CU920 with a USB cable to connect to the Internet.Log on to the LG website and download the modem driver for the Vu CU920 to your computer's desktop.
  • 2 Install the modem driver by double-clicking on the program icon on your desktop. Follow the instructions in the install wizard until it is complete.
  • 3 Plug a LG Vu CU920 USB cable from your LG Vu CU920 into an empty USB jack in your computer.
  • 4 Click the "Start" menu and select "Control Panel."
  • 5 Click "Network and Sharing Center," then click "Set up a Connection or Network."
  • 6 Click "Set up a Dial-up Connection." This will open up a window where you can enter your LG Vu CU920's information.
  • 7 Type the cellular dial-up connection number in the Dial-up Phone Number field. This number differs between each cellular provider. Contact your cellular provider to get the number that it uses for this sort of connection. Leave the username and password blank. If you like, you can enter a name for the connection in the "Connection Name" field.
  • 8 Click "Connect" to connect to the new network connection.
  • Jan 26, 2011 | LG Vu CU920 Cellular Phone
    My computer doesnt register that I have connected my cellphone
    Hi you need to install the software for the phone into the computer then connect the phone to the computer once you do this the computer will recognize it.
    Jul 11, 2010 | Samsung SGH-E350 Cellular Phone
    Can I use the Samsung alias 2 is an Internet modem
      Using Alias 2 as Modem
    1. The Alias 2 can, in fact, be used as an external modem to connect your computer to the Internet. To do this, the phone must plug into the computer via USB. The USB data cable specific for the phone is purchased separately and can be found at most any cellular phone store and eBay. Because USB is a powered connection, anytime the phone is plugged into the computer for use as a modem, it will also remain charging, so you don't have to worry about battery life while online.
      In addition to the cable, you must subscribe to a specific service through your cellular provider in order to use the Alias 2 as a modem. This plan will be a "tethering" plan and will have a separate charge each month to use it, similar to a cell phone's data plan. By signing up for this feature, your phone will be able to dial into the data network and utilize the Internet connection as a modem, allowing any connected computer to surf the Internet. Once this feature has been activated on your account the option will become available on the phone itself to enable tethering.
      At this point, you should be able to turn on tethering, connect the phone to your computer via USB cable and select the phone on your computer as an Internet connection source.
      It is important to note, however, that the Alias 2 uses a different and slightly older system on the 3G cellular network. Because of this, using the phone as an external modem will produce a slightly slower Internet connection than a traditional modem or even a newer phone would. However, as a backup solution for Internet connectivity or a travel solution, the Alias 2 will work just fine as a modem for your computer or laptop.
    Apr 01, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
    How can I connect my cel phone to the computer without the cd driver??
    a usb cable...
    if your computer has bluetooth you should be able to connect the two via bluetooth manager on the computer the same way you would connect your phone to a headpiece
    otherwise you can transfer files from a micro SD card from the phone to the computer
    Nov 04, 2009 | LG enV VX9900 Cellular Phone
    K599 phone not getting connect to PC. laptop suggested that the USB is not recongnized
    Connect the phone to the computer by way of USB, when it state that the computer doesn't recognize it, re-start the computer with the phone connected. It should recognize it now.
    Oct 29, 2009 | Dual Electronics CECT P168 Cellular Phone
    How can i install songs in my phone
    Hi friend,
    Could you tell me if you have insert a memory card in your cellular phone? The store space of cellular phone is limited,if you want to store much songs and movies,you may need a memory card.
    You can download the songs and movies to your computer first, then transfer them to your cellular phone by the USB cable,just connect your cellular with your computer ,after your cellular be recognized by your computer,then transfer the songs and movies in your computer to your cellular phone.But first you should confirm if your cellular support the format you have downloaded.
    If not,you may need to download a format change tool in the internet, and use the tool to change the format by your computer then transfer the movies that has been changed format to your cellular phone.
    Welcome to our website: www.1010store.com, you can get much useful information.
    Sep 24, 2009 | Cell Phones
    How do I download a picture from my Samsung cellphone to computer. I have the USB plugged into the camera and computer but can't figure out how to download a picture I took on my cellphone to a computer....
    Hi friend,
    Could you tell me if you mean to download new pictures or just copy the pictures that have in your cellular phone?
    If you just need to transfer the pictures in you cellular phone to your computer,you just need to connect your cellular phone with your computer by the USB cable,after your cellular phone be recognized by the computer,you can start to copy the pictures.Find the disk of your cellular phone in the computer and choose the folder that you have store your pictures in,may be the "Photos" folder.Then press the right button of the mouse and choose the "send to" option and find the disk of your cellular phone.
    If you have any questions about cell phones ,you can visit our website:
    www.1010store.com
    Have a good day!
    Sep 23, 2009 | Samsung SGH-D900 Cellular Phone
    Copying phone numbers from phone to computer
    i have lost my cd which was provided with N72 set. how can i connect the phone with computer now for trasfereing phone numbers to computer
    Aug 03, 2008 | Nokia N72 Cellular Phone
    Connection to computer
    necesitoel software de instalacion del motorola v3 black
    Feb 28, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Need to transfer photos from Samsung Sync phone to PC with Windows Professional
    i have samsung model E600 cellular phone need to transfer photos to pc , have a usb connection, but cannot transfer photo to pc my computer recognize it as unknown
    Jan 19, 2008 | Samsung SGH-E600 Cellular Phone
    Cell Phones Logo
    37 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
