Question about Rocky Mountain Hardware Shower Curtain Rod and Brackets w/ 12 Hooks
Adjustable (tension) shower curtain rod too long
The standard adjustable (tension) straight shower curtain rods (42'' +) are still too long for my 75 year-old shower stall (38.5''). Can I cut one down? I need an oiled bronze finish for stone walls.
  • 132 Answers
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
Posted on Nov 16, 2009
  • Laura Lee Aug 14, 2012
    cutting the smaller diameter isn't going to help. The larger diameter is about the minimum lenth so you would have to cut that down as well.
    President:
  • 2,702 Answers
Yes you can if you cut the right end off it
How to install a tension shower curtain rod
Twist the rod to lengthen it. It has to have tension on it to hold it in place.
Oct 30, 2016 | Cars & Trucks
TENSION SHOWER CURTAIN ROD INSTALLATION
Extend the rod until it reaches both sides. Hold one side of the rod while turning the other end until it expands and has tension. Good luck!
Oct 30, 2016 | Home
I need a shower curtain rod that won't rust/corrode
For rods that won't rust you might need a rod made of stainless steel or even nylon. This site sells these type of shower rods:
http://www.showerrods.com/
Nov 30, 2012 | Home
I PUT UP A CURVED CURTAIN ROD. IT KEEP CUMMING OFF THE WALL
These rods need a little more support than a standard rod because of their shape. I'm assuming you used a plastic wall anchor in the gyproc or plaster. If so get rid of it and use a butterfly style anchor. The butterfly provides superior support and will allow to tighten the screws more tightly than with the plastic wall anchor. Good luck with your project and let me know if I can be of any further help.
Jul 30, 2010 | Rocky Mountain Hardware Shower Curtain Rod...
Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Polder Duo Shower Curtain Rod Instructions
Cindy,
This might help you out.
http://common.csnstores.com/common/marketing/uz1194manual.pdf
Feragola
Nov 22, 2008 | Home
How to Install Shower Curtain
If you are going to use both a shower curtain and a shower liner, you have two options for installation. You can either use one rod and one set of rings, or you can use two rods and two sets of rings. If you used one rod, line up the liner and the curtain so they are facing one another and thread one ring through each of the corresponding grommets on the both the liner and the curtain. The curtain liner will move as one unit. If you use two rods, you need one set of rings for each, and the liner and the curtain will move independently.
Aug 27, 2008 | Moen Sienna Towel Bars Black Bathroom...
Rocky Mountain Hardware Shower Curtain Rod  and Brackets w/ 12 Hooks Logo
2,578 people viewed this question
Top Rocky Mountain Home Experts
Donni Steen
Tom Chichester
Are you a Rocky Mountain Home Expert? Answer questions, earn points and help others
