Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
Mac froze, will not re-boot
Mac froze, I turned it off manually (held power switch till hard drive turned off) and when I re-booted it I get a blank screen and the computer beeps 3 times in intervals. I also removed the battery, re-inserted it and it still does the same thing. Help? Thank you!!
  • 1,305 Answers
3 beeps means that it's not detecting the ram cards. It could be you have a bad ram card or simply need to remove and reseat them back into their slots.
Here is a link to a free downloadable how-to guide for your mac laptop... CLICK HERE
Posted on Nov 17, 2009
I experienced the same situation and solved it by resetting PRAM by holding the "COMMAND" "OPTION" "P" and "B" keys upon startup.
Posted on Jan 27, 2010
  • 846 Answers
Your DDR2 Ram chips are not seated correctly. There are Mac Repair Guides that show you how to reach the Ram Modules to properly seat them If that doesn't cure the problem you may have a logic board issue, that would be addressed by the Apple Genius bar and if you are out of warranty any third party Mac Repair place. iSlate Repair.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
It could be that your RAM is loose. Open the macbook back up and take out the memory and reseat it. This article could also help you diagnose the problem see http://support.apple.com/kb/HT2674
Hope this helps.
Posted on Nov 18, 2009
  • 42 Answers
Hello!
If you have a mac then three beeps and a black screen means you have a memory fault. This means the computer cannot find its memory. If you take out and re-insert the memory this should fix the problem. If this does not, contact Apple support for more help if needed.
Posted on Nov 16, 2009
  • 24 Answers
Sounds like your hard drive has gone south. You may have noticed it slowly getting slower or random clicking noises coming from inside. Sometimes hard drive can just go but usually you may have had some of these types of things happen before it just stops. You will need to take it into apple if it is under warranty, if it isn't then you have the option of installing a third party hard drive, if you have the 13in macbook or the new 15" unibody macbook pro this is really easy. Hard drives in the latest macbooks are just laptop sata drives.
What do i do - my iMac 2011 won't turn on - I just hear a whiring sound every so often
Hi Noelle
Probably a bit late now.... but for others
Determine if Hardware Problem or Software.
Remove all peripheral plugs. Just in case of bad shorted device.
Restart & hold Cmd Shift Option Delete keys down. 4 Keys
Resets Parrameter Ram. Eg Clock & mouse settings.
But might help.
Reboot with Shift key Held down. (Safe Boot)
Does it boot up?
Boot with Option key down & choose "Recovery" startup just to prove hardware (CPU) is working.
Internal Hard Drive may be damaged!
Plug another Bootable drive into USB or FireWire Port and reboot with option key held down.
If you can get your Mac to boot.... Install a clean OS X onto a USB memory Stick (16 or 32gb)
Keep this for Booting Problems & Emergency Booting & access to repair software e.g. Apple Disk Utility
or My Favorite Utilities
Bootable Backup Software
http://bombich.com/download
Directory Repair & File Testing & Fixing
DiskWarrior 5 The Disk Utility for Mac Disk Repair Mac Directory Repair...
Cheers
How about an Tick of approval for the effort?
May 13, 2015 | Computers & Internet
Hello, I had purchased one of your external hard drives and used it for years. Now I can not get it to boot up. I have a older Mac 4G workstation. my question, how do I get it to boot up? Thanks
If the unit has power, and is connected, the drive inside the case may have failed. Most external case hard drives have short lifespans due to the heat generated and held by the case.
Jul 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
The power come on but the harddrive will not boot since there is nothing shows on the screen. The screen is blank, no apple sign, no sping gears. pls what do i do,and my mac os that comes with the system...
With regards to the blank screen, this usually indicates an issue with the hard drive being faulty (hardware) or the OS might have corrupt system files (software).
These are the items you will need before we begin:
A. Mac desktop/laptop B. Mac OSX Installation DVD
A. Software Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Skip down to Section B, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Follow the installation prompts. 8. Once completed, the desktop/laptop will reboot and after logging in, will execute the registration process. 9. Complete the registration exercise and access the desktop. 10. Perform a software update and download all system and application updates to their latest versions.
B. Hardware Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Restart the computer and skip up to Section A, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Close the installation application and select "Disk Utility" from the "Utilities" menu option. 8. When Disk Utility loads, look to the left-hand pane and locate your hard drive (if detected). If so, click on it and format the hard drive then reboot and skip up to Section A, step #1. If the hard drive is not detected, then the hard drive has malfunctioned and needs to be replaced.
Hard drive's cost from $40-100 for sizes ranging from 40GB to 1TB. Once the hard drive has been replaced, you can install OSX from the installation DVD.
Aug 11, 2010 | Apple PowerBook G4 Mac Notebook
Computer froze and will not restart
You need to reset the firmware.
Remove the battery, and boot up but holing the power button down until you hear a loud Beeeeeeeeep, and the lights start flashing. Let go, and wait.
Regards.
Jul 21, 2010 | Apple MacBook Pro Notebook
Macbook turns on but screen is blank .the arrow pointer came on for awhile but went blank and stayed blank
Try holding down ALT while booting up and select Macintosh HD. If that doesn't work try inserting your mac osx install CD or DVD restart hold down ALT. Select the CD using the arrow keys after the CD has loaded go up to the drop down menus and go to disk utility, then click on your main boot disk (macintosh HD) and under the First AID tab (if your using osx) click verify permissions and restore permissions, then click verify disk and repair disk. Try to boot up. If this doesn't work restart leaving work mac osx CD in hold down D then follow the disk checker steps. This will tell you if there are any errors on your disk (hard drive). If there are you need to get it fixed or replaced. If none of this works you will need to buy a 8.1gb pen drive mac osx 10.6 update ($30 USD) then follow the instructions from http://www.maciverse.com/installing-snow-leopard-onto-an-external-hard-drive.html to create a temporary start up disk. Then go to your old Hard Drive Macintosh HD (should be on the desktop) and copy/backup important files and then turn off and get a new hard drive try Ebay and ask if it will fit your macbook by using your model number found under your battery. Find instructions for install or take the hard drive to a pc shop and ask for them to switch them over. If they don't copy your old files you will need to do a fresh install with your mac osx cd/dvd.
Note: You can use the pendrive as a temporary for as long as you want, to select it hold down ALT at startup and select the disk thats not macintosh hd or a cd/dvd. If you can't find an 8.1gb pen drive get a 16gb pendrive. sorry about the URL the link button wasn't working for some reason
Dec 20, 2009 | Computers & Internet
Frozen Mac Book now with blank screen and 3 beeps
Pull your ram cards and restart... see what you get. Then restart WITH them... you may just have an unseated ram card.
Nov 17, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Same problem!
I would boot the computer in safe mode and here is the instructions.
Learn how to start up in Safe Mode.
Products Affected Mac OS X 10.4, Mac OS X 10.3, Mac OS X 10.2, Mac OS X 10.5
To start up into Safe Mode (to Safe Boot), do this:
  1. Be sure the computer is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
  4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
while your in safe mode see if you can uninstall the drive software and reinstall it
Jul 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Screen goes white, flashing a folder with a question mark
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
May 17, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Harddrive does not boot up to desktop
It is the hard drive. The EXACT same thing happened to me. You will need to replace the hard drive. You can backup all the info onto another computer using a firewire cable as I did. Boot your computer and hit "apple" "T" while booting, a firewire logo should appear and bounce around the screen. Makes your computer a giant external hard drive.
May 11, 2008 | Apple iMac G4 Desktop
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
451 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
