Question about Homelite Garden
When i press the throttle handle the flap does not moveon carbeuter
  • 1,498 Answers
The throttle cable is either broken or disconnected at one of the ends.
I don't know your model, so I'm going by what most Homelites have in common.
I'd start by seeing if you can get a clear view of the carb where the cable connects. If you can't, start with the easier of the two areas. Dismantle the housing around the throttle handle. Most Homelites use Torx-25 screws, so you'll need some Torx bits.
You want to make sure the cable is connected to the throttle handle and the sleeve is secured so it doesn't move.
Same deal at the carb end.
If they both are connected and pulling the throttle has no effect on the carb, the cable has a break and needs to be replaced.
Hope this helps
Mike
Posted on Nov 17, 2009
How do I line up centre rod on dco7 when flap is closed
Hi.
I assume you have unscrewed the handle from tje cyclone whilst the bin is still attached. Its a common mistake to make. There is no wY that you can open that flap without the rod.
Next time ensure you take the bin off first.
Right, the only way you can get the flap open is to use the rod.
Unscrew thevrod from the handle and then hold the rod above the cyclone and insert the rod into the cyclone lining it up with the catch at the bottom. once its in pree the button and flap will open. Whilst pressing the button use your other hand to lift the cyclone off the ground so the flap will have space to open.
Jun 08, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Ignition Problem
If no engine codes are present, remove the air intake duct and check your throttle body for dirt. Operate the throttle by hand and look inside where the flap reaches the body. Usually, when this area is gummed up the idle won't be good and, when pressing the gas it will lurch suddenly. Clean this area and the butterfly or (flap) while being held open on both sides. The body around the flap must be thoroughly cleaned as well with a spray can of carburator cleaner and a lint free cloth. Hope it helps.
Feb 07, 2014 | Hyundai Cars & Trucks
Why would idle fluctuate on a 1993 3.0 mercury sable
A common thing in fords is the trottle body getting carbon deposits. I would take the tube going into the throttle body off which will expose your plates that flap open and close as you press and depress the gas. Get yourself some throttle body cleaner, open those flaps up and clean real well. I use a stiff toothbrush and wipe with a rag when I do this. I hope this helped and good luck
Feb 12, 2011 | 1993 Mercury Sable
Why does the truck shut off when I turn the air conditioner on?
I JUST HAD SAME YEAR AND MAKE VEHICLE IN SHOP FOR SAME COMPLAINT AND THROTTLE BODY COKING WAS THE PROBLEM THIS VEHICLE SHOULD HAVE DRIVE BY WIRE SYSTEM MEANING NO THROTTLE CABLE THE THROTTLE BODY IS ELECTRONIC AND HAS ACTUATOR MOTOR TO OPEN AND CLOSE THROTTLE PLATE REMOVE INLET AIR DUCT @ THROTTLE BODY PUSH FLAP OPEN WITH FINGER I SET THE HANDLE OF MEDIUM SIZE SCREWDRIVER UNDER IT TO HOLD OPEN CLEAN THE OUTER EDGE OF FLAP AND THE BORE WHERE FLAP RESTS IN CLOSED POSITION YOU WILL SEE THE BLACK CARBON DEPOSITS MAY NOT SEEM LIKE ALOT BUT THE SYSTEM REQIURES A SET AMOUNT OF AIR @ IDLE AND THE DEPOSITS HENDER THE FREE FLOW OF AIR HOPE THIS HELPS AND NOT CONFUSES IF IT DOES NOT WORK REPOST @FIXYA
Jun 25, 2010 | 2002 Chevrolet TrailBlazer
Need to know how to remove and clean or replace mass air flow sen
Get a spray can of throttle body cleaner.Take the big hose off coming from the air cleaner to the throttle body.Get someone to press the gas petal or do it yourself under the hood.Look inside the throttle body and you will see the flap opening and closing.Spray the cleaner on the flap and inside the throttle body and clean out all of the black stuff .Do not use carburetor cleaner it will damage the throttle body.It is best to replace a drive axle with a rebuilt one when the boots are busted.Trade yours in for a rebuilt axle this will fix all of your problems.
Jun 25, 2009 | 1997 Buick LeSabre
My gas pedal is sticking in my 2000 camry
This is due to the throttle flap sticking within the throttle body. The throttle flap is operated by the accelerator cable which turns the semicircular control on the throttle body. Remove the air hose to get access to the throttle body. Use carburetor cleaner to clean out where the flap sits in the body. There'll be lots of black gunk to remove with cleaner on a clean cloth. Reassemble and no more sticking accelerator.
Jun 19, 2009 | 2000 Toyota Camry
Throddle body sticking, bought cleaner for it, where is it located
From your air filter follow that black intake hose to its end, there is a clamp at the end. That's where your throttle body is located, its like a trap door/flap/butterfly. Make sure you are using intake cleaner and a clean rag to spray and wipe clean Open flap can be done by pressing on gas pedal(may need help with this) keep open and spray into throttle body , when this is sticking most of the time the flap/butterfly is very very dirty fully of a black greasy gummy substance. when clean it should return to its original color of metal. Good Luck contact if you need more help
Dec 28, 2008 | 2002 Cadillac Deville
Choke sticks in winter
clean the throttle body and flap. with the a tooth brush and throttle body cleaner from the parts store.this should fix the sticking im not sure about your stalling problem. also after you clean the throttle body and flap. it will be hard to start at first until all the cleaner burns out of the engine. its normal and will clear up in a minute or so. make sure you clean both sides of the flap. by holding the throttle open while brushing and spraying into throttle body. good luck.
Nov 22, 2008 | 1996 Dodge Ram
Dyson DC07
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Oct 10, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Garden Logo
169 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
