Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Hello, i have a preario f700 and i am not sure what happened but there is a switch on the front of it to turn on and off the network adaptor and when you turn it on it normally changed from orange to blue. now it wont turn blue nor will it get me online, can u help?
  • 691 Answers
Hello, thank you for using FixYa.
can you right click in the bottom right on the wireless icon and check the networks avaiable
this will check for any wireless around you, then you can manually log in
Once been manually login it will relogin when in range again
Thanks
Richard
Posted on Nov 17, 2009
Exclamation mark by network adaptor f700 presario compaq laptop
You can download the LAN and device drivers from theCompaq/HP WEB support/download page. Make sure you select your model laptop andthe Windows drivers you require and install them. Click on this link todownload the drivers: -
www.compaq.com/country/cpq_support.html
Feb 05, 2012 | Compaq Presario F700 Series Laptop...
No wireless
If your laptop has a physical wireless switch on the side or front, make sure it is on. You can also check in the network adaptors to make sure there's nothing wrong in there. Please post a comment if you need help finding either.
Mar 05, 2011 | ASUS U50F Notebook
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
Compaq presario f500 wireless not working
Hello, I too had the same problem: wifi card does not exist in the network switch and light orange. I solved it this way: I unscrewed the screws at the memory compartment where it also houses the Wifi card, next is the battery backup of the bios, I pulled gently on the battery connector and I shorted the two pins for 1 minutes, I reconnected the plug closing the compartment and access your PC and Wi-Fi switch has returned the little light blue and WiFi networks are detected. I hope that you too can be solved in this way. Hello Michael
Feb 13, 2011 | HP Compaq Presario F500 F700 and G6000...
My compaq G60 laptop dont have ethernet lan driver how i can solve this.
buy a adaptor callled "USB LAN adaptor" ....connect to ur USB port and then connect the LAN cable to that adaptor...ur USB port turns to a LAN portb67261b.jpg
Feb 02, 2010 | HP Compaq Presario F500 F700 and G6000...
My Microsoft Xbox 360 Wireless Network Adapter stopped working.
Shut off your console and unplug everything.
Connect the adapter then connect the console back together...Turn on console......Go to network configuration...Make sure u are connecting the adapter from the back!
If you are not able to achieve a connection for several attempts this means your should check warranty status for the adapter also.........If you unplugged it while the console was one you could of shocked the cable an blew the fuse.......Normally when u detach any components with a usb port u should alway make sure every thing is shut off before so.
www.xbox.com/support
Jan 14, 2010 | Microsoft Wireless Network Adapter Xbox...
Wireless connection will not turn on has x ove signal strength tried using window flag plus x shows icons all work except wireless con wont turn on
Hello
I am going to assume that you never had wireless connection with your 3680. With that in mind, Go into Control Panel to make sure your wireless connection can "see" other network routers. Control Panel>Network and Internet Connections>Network Connection. When you start the search for networks, this should turn your wireless adaptor on to perform the search. If you get a message that you do not have a wireless adaptor, use the Wireless Network Setup Wizard.
Good Luck
C2Solutions
Oct 19, 2009 | Acer Aspire 3680 Laptop
Cant get the wireless to turn on
There is a switch in the front of the laptpo. You need to switch it on. The light orange indicates its off and blue light means the wireless is on.
Also go to device manager and under network adaptor make sure the wirless adaptor is installed
Jul 02, 2009 | Compaq Presario M2000 Notebook
Wireless doesn't work on f700
The internal network adaptor may be fragile, and not secured properly. However, I would not suggest you try to secure it as it may break.
So, just make sure your wireless LAN device driver is properly installed. TO check, right click my computer, properties, then "hardware" tab, then device manager. There, check for your driver under "Network Adaptors" and see if it is properly installed.
If it is not, you can re-install it from the company's support& download site.
If it is installed, go to a more experienced techician to securely fasten the internal network adaptor in place.
Jun 19, 2009 | Compaq Presario 700 470024-192 Notebook
Wireless not turning on
If you can’t see it in the device manager under network adapters or unknown devices, it’s probably a hardware failure
Oct 13, 2017 | HP (407576-001) 802.11a/g/b Wireless...
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
