MONROE PM 315X SHREDDER PARTS
JANUARY 9, 2008 I HAVE A MONROE PM 315 X CROSS CUT SHREDDER SN# 558109/W205176.UNIT RESET SWITCH NO LONGER FUNCTIONS , NOR DOES THE REVERSE SWITCH. ARE THESE PARTS AVAINABLE FROM ANY SOURCE? I THINK I CAN FIND A QUALIFIED TECHNICIAN IN SEATTLE TO INSTALL THE PARTS AND GET THE SHREDDER WORKING AGAIN. THANK YOU FOR YOUR PROMPT REPLY PLEASE ADVISE. BOB VALLAT (206) 728-6200 OFFICE (206) 443-1809 FAX [email protected] E-MAIL
6ya staff
SOURCE:
Marty marty
  • 883 Answers
SOURCE: Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Posted on Jun 14, 2007
Anonymous
SOURCE: repair parts for 15mx shredder
Tel. 1-800-222-2310 For Replacement parts.
Posted on Jan 19, 2008
Anonymous
  • 102 Answers
SOURCE: fellows paper shredder
First try to clean those sensors with a qtip dipped in rubbing alchohol if that does not work call 1-800-945-4545 to check for part availability.
Posted on Apr 07, 2008
Anonymous
  • 102 Answers
SOURCE: office max paper shredder switch
If you are referring to the paper feed sensor switch in the paper throat it sounds like the pc board or switch itself may be bad. I could troubleshoot a little better if I actually had you on the phone. A Customer Service Rep can help you at 1-800-945-4545.
Posted on Apr 29, 2008
Anonymous
SOURCE: shredder parts
alot of the smaller paper shredders are desinged to be thrown away. you get what you buy, if you spend $50, instead of $500 you will be replacing it consantly
Posted on May 22, 2008
We bought this shredder in January and it no longer seems to shred.
Drive mech depending on type it may either be a drive belt or adjustment of mech
Apr 30, 2015 | Omnitech 12 Sheet Cross Cut Shredder
Emerson cross Cut Shredder X822 how to check Steel Interlock switch at bottom of unit?
Brian, a lot of shredders have a microswitch in the bottom of the unit that has to be activated by a tab on the basket. One possibility is that the tab has broken off, which means that you would need a new basket, or there is a possibility that the shredder head is on the basket backwards and is not connecting with the tab. Hope this helps.
May 22, 2014 | Shredder Office Equipment & Supplies
Overload error message?
1. make sure your waste bin is regularly emptied.
2. This is a cross-cut shredder...make sure you regularly "oil" the unit with shredder oil.
3. If the overload light will not go off at all,... then you have either a PCB or Motor problem...would suggest you contact Royal at 1-800-524-0799 for parts assistance.
Feb 01, 2011 | Royal VF1700MX Shredder
Our P58Cs is no longer turning on - no lights come up. We swapped the fuse in the plug with a plug that is working but this didn't help. Does anyone have any idea why
"" Unplug the unit first! "" The shredder head "top" has a small silver safety switch on the underside, this has to engage with a TAB on the side of the basket for the unit to power up, carefully look on the underside for it. put it back on the basket, once engaged it should work.
BE CAREFUL.
Jan 19, 2011 | Fellowes P58CS Cross Cut Shredder
Is there a reset button on the Royal VF700 Crosscut Paper Shredder?
No reset button just unplug it or safely lift the top out of the trash can then the Disable/Safety Switch will make it stop (located on the right side towards the back of unit
Jan 13, 2011 | Royal VF700 Cross-Cut Shredder
Destroyit 3102 drive gear part number
need the model no and sn and if it is sc or cross cut and a or b model call cooks mobile shredding inc. 901-565-8188 or email [email protected]
Mar 24, 2010 | Destroyit 3102 Shredder
Fellowes paper shredder
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
165 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
