Plug it into my computer and although it says its connected, my computer doesnt see it.
  • 6,831 Answers
Hello
Ok, if the computer makes a sound, without notifying you that the device is not recognized, here is something you can try.
Go to:
Start
Control Panel
Administrative tools
Computer Management
Storage
Disc Management
Now you should see your Mp3 drive in the schematic below, right click on it and choose to assign new drive letter and paths.If there is no drive letter assigned to the drive, assign on, otherwise just choose the option to change the drive letter.
Hope this can help you.
Kind regards
Andrea
Posted on Nov 16, 2009
I have a Singer Futura Quartet and when I try to use the embroidery function I get an error message that says my machine is not turned on or the cable needs to be connected. everything is connected
If your computer indicates that there's no USB connection to the machine, and therefore the Futura program refuses to start, there are several possibilities. The most likely is your cable is bad, although I have had USB cables that worked fine elsewhere, but didn't on the machine. Try switching the cable you're using with your printer cable.
Sometimes if you originally installed it using one USB port, it doesn't want to work if another port is used. Although I have not had that problem on this line of Futuras, others have. Try switching the port you're using.
Another possibility is the USB plug on the machine doesn't "seat" very well. That's true of all the Futuras. Make sure that the plug is sitting squarely in the machine. Personally, I tape the plug in using masking tape, then plug and unplug it from the computer side.
Sep 28, 2016 | Singer Sewing Machines
How do I fix the connection to my iPod, as when plugged in it says internal error
Make sure your computer is connected to the internet and see if windows updates the driver automatically when you plug it in to the USB port(s) on your computer.
Try going to the Device Manager and scroll down to where is says USB Root Hub. Right click on the top one and click uninstall. Then do this for all the others (although your mouse and keyboard might stop working, so you would have to unplug them and plug them back in again. Then go back to device manager and uninstall all the USB Root Hubs.
Restart your computer and the drivers for the connected USBs will be automatically installed.
Also, check you are using a usb 2.0 and not a 1.1.
If it still doesnt work. Take some isopropyl alcohol (90%) and a cue tip and clean out the USB port on the iPod charger and then plug it after (after it drys) and see if it works. If not, then clean the computer USB port with the cue tip and isopropyl.
Also, check your BIOS to make sure USB options are enabled.
Furthermore try a different ipod cable... However, I found that while the device is plugged in, try twisting the cord with your thumb and index finger, klnd of rolling it so the cord gets twisted. That might be enough to complete the circuit caused by fraying of the cables inside.
Good Luck
Sep 06, 2014 | Computers & Internet
Can't surf the internet. Says it's connected to my router but web pages not found
in that case i would first of all i would unplug the internet cord and then wait a minute and then plug it in and then try again and if that doesnt work try rescanning the internet connection
Dec 31, 2010 | Computers & Internet
The volume on the monitor doesnt work, even though the computer indicates it does, the test for volume shoes so, and the volume on the mixer is on and optimal. I have tested music, which didn't make any...
magus, Is the "audio cable" connected to the back of the W19B monitor? Are any ear "buds" plugged into the front of monitor??
Can you hear music coming out of the "mint green" audio connector on pc if you plug-in a set of "ear-buds" to the pc?
12fixlouie
Sep 23, 2010 | HP W19b LCD Monitor
My Computer and iTunes does not recognize my iPod
put your ipod in disk mode by following these steps.
press and hold the Menu and Center buttons on the clickwheel. when you see the apple appear, switch your fingers to the center and play/pause buttons.
whena check mark appears plug it into you computer and it should detect and mount.
add music and have fun.
May 24, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
No internet connection
re-install all network drivers or uninstall all network drivers and install again the drivers
Apr 05, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Monitor says no signal
this could be a multitude of things. Firstly, check the connections from your computer to your monitor, unplug them and plug them back in, make sure the thumb screws that connect your monitor to your computer and nice and tight but dont use a tool to tighten them, hand tight is good enough.
If that doesnt work, then check that your graphics car hasnt been unseated from its slot, TURN OFF THE POWER to your pc, open the case and look at the graphics card inside. Push it straight back against the slot and that might help.Try connecting the monitor to another computer, although I dont think its a monitor problem. or borrow a monitor from another computer and try it. If that doesnt help then you can try a different graphics card, if you dont have one they are readily available from most major electorincs stores, or even most supermarkets with an electronics dept. Now if you do all this and it doesnt fix it then you will need to find a tech to have a look at it, Like I said at the beggining it could be a multitude of sins, a hardware error stopping the computer from booting and that requires a little technical knowledge
Aug 12, 2008 | Northgate (STAX2517C2) PC Desktop
Moto Q charger problem
If you plug the charger into your phone and the battery icon does not change, then it means your physical connection is loose. If the battery connection does change but will not hold charge, then the battery is dead. I have managed 20 Q's in our office. Most of the time we just buy new batteries. Sometimes I fixed the connection by doing the following:
Use a needle nose plier and squueze the mini usb tip on the chargerslightly...very slightly. This will give it a "tighter" fit when you plug it into your phone. Make sure it's unplugged from the wall when you are doing this =).
Aug 12, 2008 | Motorola Mobility Moto Q
Hp screen problems
Pls check if the connections are proper and if the monitor is turned on.
Once you have checked the above thing, if the screen still doesnt come on, then the monitor has to be serviced or you may try connecting another cable from the monitor to the computer.
Jan 08, 2008 | Gateway FPD2275W LCD Monitor
 Grubhead
Grubhead
