Question about Compaq Presario sr1403wm AMD Sempron 3000+ Computer PC Desktop
Cooling tower fell off a chip on the motherboard and i need to know what the chip does
  • 5,603 Answers
USUALLY the chip is the main CPU OR the VIdeo Processor.
Posted on Nov 16, 2009
  • 134 Answers
You can put it back using a iron solder to attach again the 2 holders just like i did it
Posted on May 03, 2011
I need a picture of what the insides of the tower looks like a plug fell out
Tell me what is the wire color ? it should be nothing other than the LED light / reset / power button.. Just confirm me if all the front panel buttons are working ?
this is the motherboard picture but it wont help unless you find what is not working in ur pc - https://www.blueraven.com/BlueRavenResource/ItemimagesLegacy/Z3807-0.jpg
Jan 28, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
I have an IBM tower with Intel Pentium 4 and Vista operating system that worked fine when I stopped using it a couple of years ago. Now when I try to use it , I get a no signal to monitor, and the monitor...
open the tower and remove the Ram chip gently from the motherboard and clean the edge of the Ram chip that goes in the motherboard using a eraser. Reinsert the Ram chip back in the Ram slot and try booting again. since the PC was not used for a while the edge of the Ram that goes into the motherboard attracts carbon and dust and rubbing it with a eraser and reinserting the same back to the motherboard has a 90% chance that will get the system to bootup again. Good Luck
Feb 06, 2012 | IBM Computers & Internet
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
My P4B533 is not starting up anymore. Coolers are running, hard drive lights on, even Motherboard green light on. After start up the monitor goes on standby. Changed teh C-Mos battery but no luck.
its eather your fuse which no it your steal tower or aluminuim tower is not on chip on mother board when that chip gets hot it resets it self its a black chip and it has to be firmely tight on chip some has a coolent fan on it and some dont mother board has it seperated in 2 parts on some computers.
Feb 13, 2011 | ASUS P4B533 Motherboard
Need manual or wiring diagram to connect motherboard wiring to tower
If you look on their website (under socket 462 motherboards) you will find a download link to the manual you want
Dec 29, 2010 | PC Chips M848LU Motherboard
What is next to the CPU that has a cooling coil
most likely it is a controller chip (Northbridge/southbridge) with either a fan or fan/heatsinc combination cooling it. some of these are screwed down , some have a pressure clip that seats into the motherboard to hold the fan/heatsinc down.
Hope this info helps you. Regards
Jul 02, 2010 | HP Vectra VL400 P3 Skt 370 Motherboard...
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
Dell dimension 8400
IT MEANS that the processor is not getting cooled enough, try turning on the comptuer with the side panel open, dont reseat the cooling tower, however also check for the four lights on the back of the tower and post the same,,
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
K8S-LA mobo heat sink fell off.
That is the 'Northbridge' chip that provides the I/O interfacing for the main chip. The heat sink is normally held on with glue as you surmised, and should be re-done with a thermal conductive glue. The glue (a silver filled epoxy) is available from MCM electronics or from Mouser. Be sure to thoroughly clean the chip and heat sink before re-gluing.
Sep 01, 2008 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Jan 06, 2008 | Gateway (4000597) Motherboard
Computers & Internet Logo
157 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
