Question about LG enV VX9900 Cellular Phone
The black button with the grey arrow on the touch screen is stuck in the top left corner of my screen and I cannot click it or move it.
How do I quit full screen?
  • Press esc button in the left top corner of your keyboard.
  • Press 3 buttons at the same time: "command", "control", "f"
  • Another way is to move mouse to the top of the screen so menu bar will appear, on the top right side there will be button with arrows.
Oct 02, 2014 | Apple safari
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
How to enable the arrow keys on Toshiba mini netbook NB205?
  1. press Ctrl+Alt
  2. press arrow key
If that doesn't help click little arrows in the corner of the screen to get to the next page or use the arrow keys to scroll to the end of each row.
When using your browse, (browsers do not have scroll bars). You can get fro link to link, using the arrows at the top of your browser page.
Also, you can use the space bar to move down the page, or hold the left click button and use your touch pad to move around the page.
Thank You For Choosing FixYa~!
Mar 22, 2011 | Toshiba mini NB205N325WH 101" Netbook ...
I have a re-built garmin 265WT. There are two arrows at the top right corner of the screen. When I push the arrow that points to the left, the number or letter moves to the left. When I puch the arrow to...
Try recalibrating your touch screen. if that does not work make sure and rule out pressure damage to specific section of screen. if it turns out to be physical damage to screen or device that recognizes touch. call Garmin for further solutions.
Garmin customer service number: (800) 800-1020
Oct 13, 2010 | GPS
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
Itouch has stopped shuffling music
When your on the now playing screen, theres a button the top left corner of the screen (looks like a circle but made of two arrows) it should be grey if its blue or blue with a #1 over it its set to repeat or repeat the same song over and over again, which is your problem.
Jan 21, 2009 | Apple iPod touch
No display on flip out screen
I have a Sony DCR-TRV30. Your camara is probably similar. On the bottom left outside corner of mine, there are two buttons, labeled "exposure" and "program AE," and a small thumb wheel above them. Set the indicator to "camera" and open the screen. Push the "exposure" button and a light grey rectangular screen with a minus sign on one end and a plus sign on the other will appear near the top left corner of the screen. Rotate the thumb wheel so that the small black square in the rectangular screen will move from the "+" side towards the "-" side while the image on the screen gets darker.
Jan 04, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
When browsing page goes very small in top left hand corner
this happen when you shrink the browser page and close it without maximized it.
open the browser page, click and drag the page to the left top corner of the screen (top left corner of the browser page is at the top left corner of the screen).
move the mouse to the right lower corner of the browser (the arrow will change to 4 direction arrow). click, hold and drag the corner to the lower corner of the screen.
close the browser.
the browser page should be full screen when you reopen the page.
Dec 30, 2008 | Microsoft Windows Vista Ultimate Edition
Start up problem
probably u deleted some files from windows ...
after booting press F8, (or F5 ..i donlt rememdber) and then select go to safe mode! If it works than try and see what is missing, and back up u;re data.
If it doesn't work than u;ll have to reinstall u;re windows ...
Aug 08, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
LG enV VX9900 Cellular Phone Logo
71 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
