Question about Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens
Nikon d40 card formatting glitch
Hi Fixya buffs, I have a fristrating issue. My Nikon d40 was working well when I used the self-timer for the first time. After a round of continuous shots on the timer, it suddenly said my memory card wasn't formatted. I lost all my pictures, but the camera formatted the card. However, one picture retaken, and my card was reading as not formatted again. Now I can't take a single picture, because my card isn't formatted, and wont stay formatted. What has happened and how cand I fix it?
  • Nikon Master
  • 5,412 Answers
The card is corrupted - just replace it
Posted on May 31, 2017
advance
  • 107 Answers
SOURCE: memory card malfunction
Pictures can sometimes be recovered by sending the card to a service provider, or by downloading software designed to recover the pictures from the card. It is not clear weather the problem is the card or the camera, however to recover the pictures from the card would be the same process. If you do not have one you will need to buy a USB card reader to load the card on the computer. Consider buying another card to test in the camera, if you so wish. If the camera is new enough also consider contacting the manufacturer for warranty assistance. David Millier Advance Camera Repair
Posted on Feb 26, 2007
  • 26 Answers
SOURCE: problems taking pictures with nikon d40
The reasons for this could be one of the following, or even combinations of the following:
1) Low light. Especially if the AF assist lamp is set to "off"
2) Trying to focus on an even, single-color surface (e.g. a wall)
3) If you have set the camera to AF-C autofocus mode, it will keep on "hunting" with the slightest move of the subjects, causing lag. If you're not shooting (fast) moving subjects, make sure it's on AF-S or AF-A
4) If you have added a filter on the lens (e.g. a UV filter), remove it and see if it helps
Posted on Dec 10, 2007
  • 12 Answers
SOURCE: can't view pictures downloaded from Nikon D40
>TURN ON D-40. >SELECT MODE " P " . >MENU
>SHOOTING MENU >GO TO IMAGE QUALITY >JPEG basic > OK (YOU MUST PRESS "OK" )
NOW TAKE PICTURES AND SEE.
A GOOD SITE FOR THE D-40 IS
WWW.KENROCKWELL.COM GO TO SEARCH AND TYPE IN "NIKON D-40" OK?
Posted on Mar 07, 2009
  • 3 Answers
SOURCE: Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Posted on Aug 07, 2009
  • 4090 Answers
SOURCE: memory card cannot read!!!
sometimes lapstops and PCS as well as Cameras can go out of line. That is the formatting in a particular PC may not be able to be read in another.
In you case this may not be so, as the card now cannot be seen. It would have been interesting to see if it could have read it before it was formatted by your laptop. Try another card in the camera first. If no other card can be read then the problem is on the read head of the camera.
This may be just dirt or damage, and it will have to be repaired. But try another card first as the card is cheaper than a repair.
Thanlks for using FIXYA
Posted on Sep 21, 2009
Nikon d40 wont shoot continuously
Check your card that it is big enough. Also, make sure to format the card before taking any pictures in the camera you are to use it. If you do not, and it has been in another camera, corruption can occur and problems as you have stated as well. The card may not be supported by this camera. Read your manual.
Reset all settings to factory defaults.
Then set them as you wish.
If the problem continues, do more testing as follows.
Remove the battery and replace it with a fully charged battery, or recharge the battery.
Hope it works
Oct 25, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
How do I turn on my self timer on my d40?
I'm going to assume you mean a Nikon D40. If I'm wrong, please reply to this post and enlighten me.
Press the [info] button to bring up the information display. Press the [i] button to put the cursor into the display. Use the multiselector to select the Shooting Mode (fifth item from the top, along the right edge of the display) and press the [OK] button. Use the multiselector to select the self-timer mode (one-handed clock) and press [OK]. Start the self-timer by pressing the shutter release button as usual.
You can change the length of the delay with Custom Setting 16.
Mar 16, 2011 | Cameras
Var hittar jag nikon d40 manual att ladda ner???????
Hej,
Du kan ladda ner handboken genom att klicka dessa lankar.
Nikon D40 svenska handboken
Nikon D40 engelsk manual
Tack for att anvanda FixYa.
________________________________
Translated using Google Translate
Mar 04, 2011 | Nikon D40 Digital Camera
Manual for NIKON D40 DIGITAL slr
You can download and view the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jan 23, 2011 | Nikon D40 Digital Camera
Timer?
Here is the button to activate the timer (circled in yellow). After it's been pressed, then push the shutter button and you'll have a few seconds (can set the timer seconds in settings) before the shutter releases and takes the shot.
Apr 22, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Nikon D40 Download Problems
It could be the card reader is unable to read the card not your pc. You might be able to get a firmware update from card readers web site.
Jun 08, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens Logo
123 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
