Question about Jenn-Air JMC7000 Microwave Oven
Jenn-Air microwave JMC7000ADB won't turn on, in any outlet. Is there a reset button or fuse?
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: jenn AIR JMC7000ADB
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: timer comes on microwave does not
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
I'm betting they do not, and that you have a defective bottom door switch or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 25, 2008
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
wpcustomer
  • 345 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My JENN-AIR Microwave Oven stop
    Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
    NAR_JennAir_CustomerExperience@JennAir.com
    and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
    Posted on Oct 27, 2010
    Jenn-air combo micro and oven
    need to open the unit up and look for a fuse to be blown..
    Jan 08, 2014 | Microwave Ovens
    How to get to fuse in my jmc7000adb
    On this model, the fuse is located in an inline fuse holder is the wiring harness.
    See these links before proceeding:
    http://031d26d.namesecurehost.com/mwd/safety.txt
    http://031d26d.namesecurehost.com/mwd/disassembly.txt
    Oct 24, 2012 | Jenn-Air JMC7000 Microwave Oven
    Micro wave not working jen air
    The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
    Sorry
    Apr 24, 2010 | Jenn-Air JMC7000 Microwave Oven
    Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
    MIcrowave quit on February 15, 2008. I can't get parts to repair
    seems like you have to replace the control/touch panel module of the oven.
    Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
    Jennair Microwave Model JMV8208AA/AC
    I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
    Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
    Thank you.
    Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
    No power on Jenn-Air JMC 7000 ADB Microwave
    I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
    My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
    Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
    I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
    Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
    Jenn-air microwave JMC 7000 ADB has no power
    Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
    Jenn-Air JMC7000 Microwave Oven Logo
    484 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Dennis Boxerman
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
