Older Sharp TV 19'' that's screen keeps dropping to just a line across then pops open when tapped on it's top.
  • 975 Answers
It s a cold solder at the VERTICAL OUTPUT IC , require a soldering tool , go to the VERTICAL section ,look under the IC to check all solder , hope it helps , AJ
Posted on Nov 16, 2009
Samsung TV thick black line running across the bottom.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
I have a Sharp aquos 60" lcd that has 1 vertical blue line on the left side off screen. what part would cause that ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sharp Televison & Video
Why does my tv have a horizontal line across the top?
Aug 30, 2014 | Sharp Aquos Televison & Video
HOW COME DOES MY SHARP LC39LE440M LED TV HAVE VERTICAL LINE ALL ACROSS THE SCREEN?
Aug 10, 2014 | Sharp Aquos Televison & Video
Blue and black lines across sharp lcd (matrix like)
Sounds like a T'Con board fault. It will be best to contact any service technician to get this TV repaired. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window
Nov 06, 2013 | Sharp LC-60C46U LCD TV
Reset a Sharp 13G M100 TV to factory settings
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Dec 01, 2012 | Sharp 19C140 19" TV
Lines across the screen
What is the brand name and model number to your TV? Anyway, visit the following site. I assumes that there are fine lines across the screen all around with an inch apart, with blurred picture as background. If so, the fault is called 'retrace lines'. There is a post discussing this type of fault. Check the link, and search it for this post. Pull up older posts there.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Check this link too.
Nov 27, 2012 | Televison & Video
Thin line across the screen
I'm guessing that this is a CRT based TV, not an LCD. That being said, the problem is a failure of the vertical circuit. Usually this is a small flat IC (LA7837 or similar). Try resoldering the pins if you can first. If that fails to resolve the problem, replace the IC. Please be aware that there are potentially dangerous high voltages present even when unplugged.
Keep us posted.
Dan
Jan 21, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Tv 25E-M50
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
May 21, 2008 | Sharp 25N-M100 25" TV
No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Toshiba 32A50 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
