Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
I have a fairly new Blackberry Pearl Flip and the battery runs down after only a few hours in the Standby Mode. If you do not turn the phone on, the battery stays charged forever but as soon as you turn it on the battery goes dead in a matter of 6 hours even if you do not use the phone.
My blackberry pearl flip shuts off and a red light
it has to be upgraded and you will lose all your data once it is upgraded it will work fine
Jul 21, 2010 | RIM BlackBerry Pearl Smartphone
I have a 6-mo old Blackberry Pearl Flip 8230 that
first try replacing the batteries with a fresh one, having a battery logo with a lightning strike states that the batteries, including the backup battery has completely dried out, try charging it for a few hours. if there is no change and you still get the logo, maybe it would be safe that you should have it check at blackberry repair center.maybe some shortage or busted parts are causing such an error on your blackberry.
Jun 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Ok so the screen on my pearl flip just goes blank or the white screen with the little hour glass comes up and itll go like that forever untill i turn it off, plug it in and turn it back on. is this a...
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working the software of your Handheld might got corrupted, in this you need to reinstal the software or walk into the service center.
Thank you for using Fixya.
Nov 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl error message
You may have a bad SIM card. Tmobile may give you a new one or you can buy one for about $20. Then call them to have the IMEI number switched over.
Aug 24, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
Mar 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
External display on pearl 8220 cracked
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
161 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
