IOGear printer server to Ricoh to Mac confusion
I have an IOgear printer server - hooked up to my "internet router" via ethernet and then from USB to my Ricoh printer 3500n - not sure where problem is - either ricoh interface setting is wrong - and/or it is the settings for "connection" to IP or DCHP (protocols) setting on MacBook3.1. Had Ricoh "interface" figured out before with MAC- but that no longer works either - when hooked to my mac mini. Now the Ricoh printer is downstairs - no MAC's are down stairs. Hoping to have everything go to my router and both macs "send" print jobs to router, which is hooked to IOGear. Is that what it should do? Sorry if this is confusing - not sure where to start. I feel like I am trying to figure out which Christmas tree light is causing them all to go dark.
SOURCE: Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
As an update:
I actually had a Ricoh tech come out to my house. It was a warranty service - I was very impressed! He did some fiddling around, said that there was no problem that he could detect but... after he left the Macs can print to the printer no problem. From what I can recall, all of the settings were identical to what they were in the first place on the Mac side.
I still can't get my linux machine to print there but it is a low priority and I am really not trying very hard.
I wish I had more enlightening input.
Posted on Nov 24, 2008
Joed911
  • 4338 Answers
SOURCE: I can't get my Mac OSX V4 laptop to print with my HP 4m+
The printer should be set with a static IP address:
(assuming that you are using the default Gateway of the Linksys router) Set the printer's address like:
192.168.1.50
255.255.255.0
192.168.1.1
There isn't a need to set the printer for "DHCP"
The printer does not broadcast IP addresses.
Try these settings and then un-install the printer and re-install it on the Mac.The Mac should see it and set it up correctly.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 15, 2009
firesnake09
  • 2923 Answers
SOURCE: IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Posted on Apr 07, 2009
Sailorm0on
  • 61 Answers
SOURCE: PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Posted on May 16, 2009
Sailorm0on
  • 61 Answers
SOURCE: IOGEAR GBP301 and HP Deskjet D1341
Please make sure that the printer is already VISTA compatible meaning if it is known to have VISTA printer drivers.
Posted on May 20, 2009
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
May 24, 2010 | IOGear GPSU21 Print Server
Can print from mac, cannot print from pc. have checked, both applications have correct printer selected
What is the operating system of your PC? Is this working before with your PC or is this the first time you are trying to install this Bluetotth Printer Kit?
If this is the first time, verify the OS of your PC. Because the USB Bluetooth adapter (GBU311) of this wireless printer server (GBP302KIT) could only support Win 98SE up to XP 32-bit (according to the system requirements).
But if this has worked before and then suddenly stopped working, try to uninstall/re-install the Bluetooth driver that's in your PC.
Everytime you are trying to detect the Bluetooth adapter that's on the printer, make sure that the Blue light is blinking (printer light).
If same problem occur, contact IOGEAR (866-946-4327). It's a free customer service support.
Apr 17, 2010 | IOGear (GBP302KIT) Print Server
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
Mac on ethernet cable to router doesn't print, but wireless XP does
printer T20E saya ngeblink apa yang harus aya lakukan...
Sep 10, 2009 | IOGear Computers & Internet
Receive communication error when attempting to print to an Epson Stylus Pro 7600 via IOGear usb print server
Try disabling bi-directional support in the printer properties to see if that helps. This can be done by going to the Printer and Faxes window then right clicking on the printer icon and selection properties. The go to the ports tab and at the bottom of that windows there is a check box for bi-directional support. If the box is check try disabling this selection, apply the change and then try printing again.
Sep 02, 2009 | IOGear USB Print Server, 1-Port [ GPSU01 ]...
IOGEAR GMFPSU22W6 PRINT SERVER not being seen by the control software that came with the hardware. Using a Wireless N router with hard wire from the router to the print server and network is up and...
For the GMFPSU22W6, there's two possible reason why it's not being seen by the MFP Control Center. First, the MFP Control Center was properly installed, second, the Print Server is not working correctly. To resolve this problem, please try the solutions below:
1. Uninstall/re-install the MFP Control Center.
2. Reset the GMFPSU22W6 by holding down the "Init" button that's located on the right side of this device. Hold it down by 10 seconds and then unplug the power adapter while still holding down the "Init" button for another 10 seconds.
3. Resealse the button and turn it back on by connecting the power adapter to it.
Mar 19, 2009 | IOGear (GMFPSU21W6) Print Server
MacBook cant locate Kodak EasyShare 5100 printer using IOGEAR bluetooth adaptor
having same problem with same devices, macbook pro, kodak 5100, and that iogear bluetooth adapter...im getting desperate...
Jan 13, 2008 | Office Equipment & Supplies
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
Nov 13, 2007 | IOGear GPSU21 Print Server
Print server won't speak to printer
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
