Question about Sony Ericsson T630
Cannot connect to my bluetooth device. T630
Cannot connect to my bluetooth device. T630 cannot find any devices
How many devices can be connected via bluetooth
Hi Sam,
  • The official Bluetooth specifications state seven(7) is the maximum number of Bluetooth devices that can be connected at once.
  • However, three (3) to four (4) devices is a practical limit, depending on the types of devices and profiles used.
  • Some devices require more Bluetooth data, so they are more demanding than other devices. Data-intensive devices may reduce the total number of devices that can be active at the same time.
  • Some manufacturers may limit the number of Bluetooth connected Devices;
  • Price & Quality may also be a factor.
If a Bluetooth device becomes slow to connect or does not perform reliably, reduce the total number of connected devices.
GL,
JP
Jun 20, 2015 | Cell Phones
I seem to have lost instructions on how to turn on the headset and pair
Bluetooth® is a wireless connectivity feature that has a short range and low power consumption. This makes it the perfect medium for sending information among devices in the same room. Using Bluetooth, you'll be able to connect to wireless headset and entertainment devices like wireless speakers. You can connect to many car infotainment systems and share your device's contacts and music. You can share content, such as photos and contact cards, between two mobile devices.
Connect to a Bluetooth Device
  1. To connect to a Bluetooth device, turn on the Bluetooth device you want to connect to and make sure it is in discoverable mode.
  2. To turn on Bluetooth on your mobile device, open the Notification Panel by swiping your finger from the top of the screen to the bottom, and touch the Bluetooth shortcut. When the Bluetooth transmitter is turned on, the icon will be green. If you do not see the shortcut, you may need to touch and hold the shortcut bar and swipe it left or right to reveal the additional shortcuts.
  3. To scan for new devices, touch the Settings icon_notifications_settings_shortcut.png > Bluetooth.
  4. Your mobile device will begin scanning for any available Bluetooth-enabled devices. If your device is on and in discoverable mode, it will show up in the list under Bluetooth devices.
  5. Touch your device. Verify the passkey matches on both devices and touch Accept. If you are connecting to an older Bluetooth device, you may be asked for a PIN. The default PIN for many devices is four zeros - 0000. Some devices have PINs specific to the device. The PIN will be in the device's documentation.
The Bluetooth menu allows you to make your device Not visible to other Bluetooth devices or Visible to all nearby Bluetooth devices by unmarking or marking the option above the Available devices list. When the box is marked, a timeout is shown next to Visible to all nearby Bluetooth devices. If the time reaches 0:00, touch the box to unmark it, and then mark it again to reset the timer.
Nov 02, 2014 | Radio Communications
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
Aug 04, 2013 | Computers & Internet
Bluetooth is not responding
which bluetooth device ? are you referring to ?
keyboard , mouse , ahh a webcam ?
Bluetooth is a wireless technology that connects devices over a limited-range network (WPAN, or wireless personal area network). Bluetooth transfers data three to eight times faster than a parallel or serial port.
Some Lenovo PCs includes an internal Bluetooth card to allow users to connect Bluetooth devices to the computer. Inactive Bluetooth support or computer settings can prevent the Lenovo PC from detecting a Bluetooth device.
Hold down "Fn" and "F5" after booting the computer or returning from standby to enable Bluetooth features. Click "Start." Click "Control Panel." Double-click "Bluetooth Configuration." Select the "Accessibility" tab. Check "Let other Bluetooth devices discover this computer." Select "All devices" from the drop-down menu. Click "OK." Double-click "Bluetooth Devices." Select the "Options" tab. Check "Turn discovery on," "Allow Bluetooth devices to connect to this computer" and "Alert me when a new Bluetooth device wants to connect." Click "OK." Exit from "Control Panel." Align the device with the Lenovo PC. Check the documentation included with the device to confirm it is the correct distance from the computer. Right-click "Start." Click "Explore" or "Open." Navigate to "My Bluetooth Places." Click "Bluetooth Tasks." Click "View Devices in Range" to locate the device. Select the device from the list. Click "Discover services" to use the device's applications on your Lenovo PC. Right-click the device and select "Connect" or "Pair" to configure the device. Hope it helps.
Jan 25, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
How do you connect a bluetooth device to your computer
If your PC doesnt have a bluetooth capability, you need to have a bluetooth dongle, this device is a USB plug and play,, in order for you to connect any bluetooth device to your PC.
Sep 18, 2009 | Gateway M305CRV Notebook
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Need a program
hi just install the sony ericsson pc suite.
http://www.sonyericsson.com/cws/support/phones/detailed/whatissonyericssonpcsuite/t630
you will eather need a wire connection or bluetooth.
Mar 29, 2009 | Sony Ericsson T630
Sony Ericsson T630 Logo
74 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
