Question about Amana SXD524VW Side by Side Refrigerator
Ice maker overflowing
I have an Amana side by side. The ice maker is overflowing. The refrigerator is only very slightly off level. Could this cause the problem?
It worked for a few years before starting to leak.
  • 4,059 Answers
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Posted on Nov 16, 2009
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Amana drs2663bw ice maker drips water into the back of the ice bin forming an ice build up
Make sure your refrigerator is level. also check that the ice maker inside the refrigerator is level after leveling the fridge.
Jul 20, 2012 | Amana ARS9266BS Side by Side Refrigerator
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    HOW DO YOU REPLACE THE ICE MAKER IN A AMANA REFRIGERATOR MODEL NUMBER SZD25NL. I UNDERSTAND THE REPLACEMENT ICE MAKER PART NUMBER IS AP4135008 MADE BY WHIRLPOOL. IS THIS CORRECT? THE ICE MAKER THAT IS...
    You may not need an ice maker. See if it is level. If the ice maker is overflowing with water there is an adjusting screw to lower the water level.
    Jan 29, 2011 | Refrigerators
    Water is dripping from the ice maker into the ice tray
    you may have a bad water valve. the valve could be not completely shutting off. when you hear the ice maker begin to cycle open the freezer door and watch it. look to see if the plastic tube coming thru the back of the refrigerator is not leaking after the ice maker has completed its cycle. if it is dripping and running over your water valve is bad.
    you may also check the level of the ice maker. sometimes you can be out of level causing a slight leak.
    Jul 11, 2010 | Amana DRS2660B Side by Side Refrigerator
    Icemaker clogs with ice. Water flows with icemaker unplugged.
    ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
    Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
    Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
    Good day,
    If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
    After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
    Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
    Dec 21, 2009 | Refrigerators
    Amana ice maker clicking - still makes ice just really slow
    level the refrigerator. i/m not level causing it to jamb and cause low ice production
    Aug 25, 2009 | Amana 25.8 cu. ft. Side-by-Side...
    Gss20iemd refrigerator.. Water overflows from the
    try turning down the pressure if that doesnt do it check the fill switch it may be stuck
    Aug 23, 2009 | GE GSS20IEP Side by Side Refrigerator
    Ice maker overfills and leaks into the ice bin.
    I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
    Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
    Amana SXD524VW Side by Side Refrigerator Logo
    138 people viewed this question
    Top Amana Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
