Question about Cell Phones
Voice dialing my phone keeps going to voice dialing and when i call someone i can't hear them. and then voice dialing pops up and i escape out of it and it comes up again.
Why can i not get a ringtone on my phone. why am inot able to hear the vallers voice when someone calls? WHY am i unable to connect with my voice mail?
The earpiece on your phone is faulty or damaged. That's why you can't hear anything. Your phone needs to be repaired or replaced.
May 29, 2014 | tracfone.com
How can I delete a voicemail message without having to listen to it all (someone must have unwittingly dialed my number).
after you enter your voice mail.just keep ponce the voice messages start just keep pressing 7 and they will go away
May 11, 2010 | Motorola Mobility W377 Met Silver/Pink...
Sonhy Ericson cell phone
Your mic is faulty. If this is on a headset, then try wiothout the headset.
Jan 12, 2009 | Sony Ericsson w580i Cellular Phone
Sony Ericsson W580i is not working.
Try this and let me know if it works, if not, I will suggest something else.
Turn off the phone, take the battery out and let it sit there for thirty seconds. Replace the battery, power up the phone and try it again. That should fix the problem.
Set up voice mail
Feature 14 comes to mind. It's the VM Transfer button for a Partner Voice Mail.
You set it up by dialing FEAT 00 press the button and dial FEAT 14. End programming by dialing FEAT 00.
To use it, when a call comes in press the VMXFR button and dial or press the person's DSS button.
Carl
Sep 09, 2008 | Lucent PARTNER18 Corded Phone
We have power but no internet or phone lights are coming on.
do you get dial tone if you lift phone handset?
If so, Do you hear the voice menu after pressing ****?
If not, please unplug the Ethernet cable, and press **** again, then check if you now hear the voice menu?
Just in case you are able to access the IVR, reset it back to factory default settings. Dial 73738# and press 1 to confirm the reset.
Jul 05, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Motorola TracFone C139: no dial-tone/no voice
Lol, i love your solution, but anyway, the cause of the problem isn't simple. First of all, if the phone has always been this way then it is a manufacturing problem. However, if it is of recently that the problem occurs, then a circuit blew in the phone. To prevent this from happening when you get a new phone, keep it cool because heat causes the circuits to be on the fritz.
Jun 15, 2008 | Motorola Mobility TracFone C139-4 Cellular...
CDM 8910 Audiovox Bell Mobility
go into the menu
go to settings
go up to go to next screen in others (the phone only shows the first 7 options, scroll past to options 8&9)
now while in "others" go to voice settings and choose "off" and then hit OK
hit the red button (off) And escape to the main screen, close your phone for 3 seconds and open it and its done.
hope this helps
May 20, 2008 | Audiovox CDM8910BM
How to turn off voice mail on A V3 RZR phone
try dialing *780, you should hear beep beep beep confirming that it is turned off. press *78 to reactivate.
Dec 26, 2007 | Motorola Mobility RAZR V3
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
