Question about Grado SR80 Professional Headphones
Left earpiece removed
The left earpiece has come detached from the headband, thoughts on getting it permanently reattached?
  • Grado Master
  • 5,151 Answers
It rather depends on what broke on it. Sometimes superglue will hold it, but in my experiance if it gets a lot of stress it will go again. Another solution, if it is plastic that has snapped, is to melt them together with heat from a soldering iron. If you do this wear a mask and do it in a well vented area. You might need safety glasses as the smoke can make your eyes sore and also seems to go there.
One further way is to remove the speakers, find the size of them, then buy a cheap pair of headphones that uses the same size speakers as yours. Fit yours in. Afterall it's the speakers that output the great sound not the case!
Posted on Nov 30, 2009
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
Quivering while excersising
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
Oct 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
My left ear piece is not working, i want to repair it
This is a very common problem with wired headphones!
The wires associated are too delicate to resist pressure or tug of any kind.
I would suggest you to get a replacement as its often not easy to repair em yourself.
Even then if you want to give it a shot read below:
But before you read any further do remember to check the headphones on other appliances as it might be the case that they are being supported in one you trying since long! If already done read further!
1. Open the left earpiece, in most off the headphones there are little 'voids' through which you can easily slide in any sharp object and open them.
2. You would be lucky if you can see the wire detached from the back of the speaker. You just need to attach it. For temporary measure you may use tape whereas you need to solder it for a permanent cure!
3. Now, if you see no breach then its alarming as the wire may have detached anywhere through the length. You either need to replace the entire wire or get a new headphone in that case!
* DO ALL THAT AT YOUR OWN RISK OR TAKE HELP OF A PROFESSIONAL! MISHANDLING MAY DAMAGE THE PRODUCT PERMANENTLY!
Aug 08, 2013 | Panasonic Audio Players & Recorders
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Grado SR80 Professional Headphones Logo
242 people viewed this question
Top Grado Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Grado Audio Player and Recorder Expert? Answer questions, earn points and help others
