Question about Navman iCN 330 GPS Receiver
I have been using it for 2006 november...now every time i turn it on in my car it says" insert navman 300 series card".. but the card is already in there...what is going on???
  • amitshah496 Nov 17, 2009
    what i can do to make this machine work?
  • 3,741 Answers
It asks for card because it isnot able to sense the card.
initially remove the card clean the connections on the card and on the device too..
1)then ON it without a card,
2)then OFF it ,
3)then insert the card and ON it again.
it will then sense the card and work properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 17, 2009
    Top Expert:
  • Navman Master
  • 76,691 Answers
There are only tow possibilities here, on is the card is corrupted and two the card reader inside the GPS is defective, try cleaning the contacts of the card if poss, if that doesn't help u will need to have the GPS checked for which is the source of the problem, the GPS or the card, there is no easy way to tell. here is a place that can diagnose the GPS for u, you can also call them for more advice. go to the link
http://www.portatronics.com/index.php?cat=c81_Other-GPS-Units.html&XTCsid=e34f3b66ce7ceeb9e424b516cad79b99
Posted on Nov 16, 2009
  • yadayada
    yadayada Nov 17, 2009
    There is not one part of this GPS that is repairable by u, if the GPS is the problem it must go into a factory authorized repair center.
Application error.
This is not an uncommon error and is mostly referred back to Nab=vman for repair
Other than sending it to Navman you can...Open up the unit (this voids any and all warranties you may still have and if you go with this option forget about contacting Navman). F20's internal flash is just a hidden micro SD card. If you don't have it already, you'll need to get a cheap micro SD card adapter -- with it you will be able to read the card with any card reader. You could then scan card for errors and look for log files that could provide more information on what went wrong with your unit.
Please rate my help++++Thans for using FIXYA
Nov 26, 2009 | Navman F20 GPS Receiver
Message on screen "Insert a SD into slot...
Normally the sd card holds the programme and the maps so the satnav will not run without it. If it is already in place, take it out, wipe over the contacts with a dry cloth and reinsert it. If there is no sd card then it will not work-it has no programme.
Jun 11, 2009 | Navman F20 GPS Receiver
Does not have all the roads on the navman
only one solution really, up date your maps. Unfortunately you cannot just update maps for the UK, only Western Europe which include latest maps for UK (November, 2008) - go to 'navman.com/' the site \is 'Navman - beyond navigation' - click on 'UK' - when page comes up click on 'visit our online store' - on the left click on '2008 software and maps' - click on the SD card for Fseries - £39.95 inclusive
Mar 13, 2009 | Navman F20 GPS Receiver
I wondered how you charge the navman s 100
According to page 3 of the s series manual, "use the home charger model MII050100 supplied by navman as an accessory (may be sold separately)
Page 10 gives more details - simply plug in the home adapter, car adapter, or usb cable from your pc into the usb socket on your unit. Computer must be turned on.
Dec 11, 2008 | Navman GPS
When I try to update my navman It says I'm not connected and I am?
Hi - yes it probably is a driver thing. Navman's install software apparently doesn't install the Windows driver - you have to do it manually.
I just found this how-to page on Navman's website, and it worked for me:
http://www.support.navman-europe.com/FAQs/Drivers/F-Series/
Good luck
Peter
Aug 12, 2008 | Navman F20 GPS Receiver
Can't read map
this will help you : http://www.fixya.com/support/t906770-no_map_displayed
Aug 02, 2008 | Navman iCN 530 GPS Receiver
Navman f20 & b2 series handsfree
I downloaded sp2 update for f20 from navman and it upgraded my navman to 4.10.1028 but still cant get caller id
Dave
Jul 23, 2008 | Navman F20 GPS Receiver
Navman F20 series not seeking gps
I have had this problem from time to time with my F20 which I have had since May 2007. The simple solution is to turn it off and then on again and let it go through it's start up sequence. It is far better for this to be done whilst stationary.
Jun 02, 2008 | Navman F20 GPS Receiver
Info on fitting a new battery to Navman PiN570
Remove SD card and place the Navman on a soft surface face down so that you do not scratch the LCD screen. - Take out 4 screws ONLY. 2 under the gps antenna and two hidden black discs at either side of the bottom on back of unit,Make sure you use a small Philips screwdriver.
- Use your finger nail very carefully around the edges, go extremely slow to detach the cover. Once it opens, make sure of the Power switch button, they seem to fall off.
- Remove clear tapes at the battery connector. DO NOT pull up the connector, you need to pull sideways and make sure do not use excessive pressure while pulling.
- Place the new battery in same manner and also place battery cables neatly so that the do not come in the way while closing the cover. The LCD display should turn on. If it does not, look at the Battery connector and make sure it is all the way in.
- Put the cover back slowly and then make sure nothing is dangling along the edges. Do not forget to check the Power Switch button; it should be in proper place. Press the cover firmly, it should snap in place.
- Charge the battery fully before using Navman.
- Insert SD card. You may need to reload Navman application software or restore from SD card, if you stored on the SD card previously.
May 16, 2008 | Navman PiN 570 GPS Receiver
Navman iCN 330 GPS Receiver Logo
107 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
