Question about 2wire 2700HG-B Router (2700HGB)
Power light is off and so are all the others...cannot connect to Internet
  • 603 Answers
Power adapter is bad, check on ebay
Posted on Nov 25, 2009
My 615s at power-up flashes its display lights, and then blinks out. When I move the Cpu ground the display lights go on (sometimes), then the green light goesoff and stays off. Any suggestions?
Check all your connections, including your power cord in back and all other connections. Unplug and blow out inside of computer. Make sure all your cards are tight. Run virus scan, clear history from tools and internet internet options.
Jun 03, 2015 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Recently my D-link has lost its connectivity, oddly my Mac computer can pick up a wireless signal and access internet while any other wireless devices fail to acquire internet. I tried a cable connection...
Hello, Looks like your Mac might have connected to some other unsecured wireless network in your neighborhood. First connect any computer directly to your modem and check if you are able to go online. If the "internet" light is not lit on the router then there is no way your Mac can access internet through the wireless signals of that router. If you do not have internet connection through your modem then contact your internet service provider. If you are able to go online through your modem then perform the following steps..
1) Disconnect the power from both modem and router wait for a minute and connect the power back for modem first and after ten seconds connect the power for your router. Now once all the lights are stable check if you are able to go online through the router. 2) If the above step didn't work then you will have to reset and reconfigure your router. You will see a small reset button at the back of the router, press and hold it for 10 seconds and let go of it( while power is connected to the router) now disconnect the power from your router and connect it back after 10 seconds. Once you have done this you can reconfigure using the disk provided with the router by re-entering the ISP information. 3) Once this is done check if you have any firmware update to your router by logging on to the router vendor's website and entering your product details.
Hope this helped..!
Mar 09, 2011 | D-Link DIR-655 Wireless Router
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
I purchased a wireless router model wrt110 early this month, installed and working fine unitl last night had to uninstall and tried to install it back i get to the installation to figure the router and i...
NO need to worry i will provide a valid trouble shooting steps
I think u have used the set up cd..dont use the Cd..i will give u the exact steps..
U dint specify that whether u r using the cable Internet or DSL!!
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid..open the internet Explorer it should work..
STeps for DSL Connection(verizon)
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a user name and password..leave the user name blank and the password will be admin.
7,linksys set up page will open..there u can see local ip address which says 192.168.1.1.
please change it as 192.168.2.1..click on save settings at the bottom of the page..
it will say like "settings are successful please release and renew the ip address".click continue or OK
8,Now turn off ur modem and the router..wait for other 1 minute..turn onn only the modem and wait till all the lights lit.now turn on the router and wait till the power light is solid.
9, Open Internet Explorer and it shuld Work....
TRY IT AND GIve me ur feedback
May 31, 2008 | Linksys Wireless-G WRT54G Router
Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Dec 24, 2007 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
