Question about GPS
Plug dry rotted and I want to hard wire the unit but the wires coming out of the plugs are different than the wires coming out of the unit...the unit is Black Red Green Yellow Gray and Blue...Out of the plug is Black Black Blue Red Gray and Yellow so wich do I match besides the obviouse..Thanks a million!!!!!!!!!!
  • 3 more comments
  • wyattlisa05 Nov 16, 2009
    Yes sir I cut the plug off of my Lowrance M68c s/map and opened up the back to my curosity I found I found that the 6 wires coming out of the GPS were not exactly the same colors as the plug wires
    I'm kinda new at this so I dont know if my last blog went through or not
  • wyattlisa05 Nov 17, 2009
    LOwrance M68c s/map I need to hard wire to unit but the 6 wires out of the unit its self does not exactly match the plug wires...Is there a wiring diagram for this please and thankyou.....
    Sorry boss I did not know anything else was needed but there is another # on the back that is 051-1938-00 if that helps...
    The type is a Lowrance M68c gps and chartplotter for a boat if that helps any
    Top Expert:
  • GPS Master
  • 76,164 Answers
U don't give any useful information here about the type of device or the model number you are asking about here?
Posted on Nov 17, 2009
  • yadayada
    yadayada Nov 17, 2009
    sorry you need to provide the exact model number, also wiring diagrams for GPS's are not available in any event, there are no owner replaceable parts and there fore no diagrams are available.
  • 19,396 Answers
Hi.
Sorry, but the problem is quite confused.
Can you tell us device make and model, and the connector that you are trying to fix, so that we can look for a wiring diagram, a pinout, or simply share our info.
Many thanks.
Posted on Nov 16, 2009
How do i know which wires go to my new head unit?
Probably need a new wiring harness for your vehicle model. Crutchfield.com is a good place because they will help you out with the wiring.
Jan 04, 2016 | Pioneer Car Audio & Video
I CHANGED THE TIMING BELT AND SPARK PLUGS AND WHEN I DRIVE THE PT CRUISER ON THE FREEWAY IT DRIVES GOOD BUT WHEN I COME TO A STOP THE PT CRUISER RUNS BAD
Does the vehicle turn off, run rough, or hesitate?
It sounds as though you have a faulty Idle Air Control Valve".
May 10, 2012 | 2003 Chrysler PT Cruiser
I have a 2003 honda shadow vt1100c spirit. it will not start but turns over fine. spark plugs get fowled with fuel . using the choke doesnt seem to make any difference, but it feels like its working ok. a...
Sounds like itermitten spark.Clean stator with electrical cleaner(under flywheel)then replace spark plugs and check for spark.then the electrical componets to check are CDI ignition box and coil.If either of these go bad you will have no spark.Check also the condition of spark plug wires and rubber boots these can somtimes dry rot and go to ground shorting out wire to plug cuasing bike not to start.
Mar 13, 2011 | 2003 Honda VT 1100 C Shadow Spirit
My heater ra50a has been sitting for two years got it out and removed all old fuel put in new will nor start. plug fires sputters but will not fire off
Replace the plug or remove and try to clean it. Also, be sure the wire running to the plug is not damaged or dry rotted.
Feb 11, 2011 | Reddy Heating & Cooling
When you excelerate the vehicle it sputters and
Attempt to change the air filter. Check the spark plug wires for looseness. Check all vacuum hoses for cracks or dry rot.
Jul 24, 2010 | 1993 Ford Crown Victoria
My truck won't start when it rains. What could
dry-rotted spark plug wires is the place to start
Jun 27, 2010 | 1998 Dodge Dakota
I have a 97 s 10 that misses in 3ed when the gas is wide open
check your spark plug wires they could be split or dry rotted causing them to arc on the block when the motor torques when your at full throttle
Mar 23, 2010 | 1987 Chevrolet S-10 Pickup
Radiator fan not running
Most fans plug into the wiring harness, plug could be corroded, also look for a ground wire with a rotted connection. Of course the fan could be bad, try wiring it direct to the battery to test it. If it works you may have a bad sensor that simply isn't telling it to come on, good luck,Chuck
Mar 16, 2009 | 1991 Dodge Dynasty
GPS Logo
81 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
