Question about Sony Playstation 3 (PS3) Console
Ps3 slim overheating - unit was running for about 5hours playing a ps3 game then the power indicator blinked red and then shut down. I'm unsure why it did this because i don't have my console in a cabinet or on any soft surfaces. I read discussions about overheatinig saying about the way you insert the power cord but i don't understand why this would make a difference cooling the system down because to my understanding it doesn't matter which way you insert the power cable. Can you please help me? thanks, Conor
  • 975 Answers
This can be caused by dust buildup in the console, causing the unit to overheat. Once the unit overheats this causes the unit to melt solder on the board making a bridged connection. This makes the board short out giving you the error you have now. I would contact sony to see if your unit is still under warranty. If your unit is not under warranty, go to www.wiredextreme.com. We are a console repair company based in Texas, and can fix your console. We give a free diagnosis of what is wrong with your unit, and call with an estimate of repairs before any work is done on the unit. All work is covered by a 30 day warranty, and you can buy up to 4 years worth of warranty.
Posted on Nov 16, 2009
My playstation 3 shut off in the middle of a game and the power light is flashing red
You've got the wonderful read light of death. I would highly recommend you getting it fixed direct through Sony.
BUT if you wanna waste some time trying to fix it yourself you can follow this tutorial here.
YLOD is essentially the same so don't get confused by all the acronyms.
Red Light specifically indicates a hardware issue, in almost every case it's because your unit has overheated.
Try removing the power from the unit for 30 minutes then try powering it back on, if it powers back up then consider yourself very lucky. To prevent it from happening again I always run a mini-fan directly on my PS3, especially when playing a game.
If you get no joy, then call Sony direct @ 1-800-345-SONY to setup service.
Hope this info helps!
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
I was playing my ps3 and during online play the game just shut down and the red light was present afterwards. I tried to go touch the on switch and it turned green for like 3 seconds and shut back down....
There are series of problem in ps3 which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the ps3 repair guide that will help you a lot....
Click here to download PS3 repair guide
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
While playing a game my ps3 shut down, and now will not turn back on. the red light is flashing on the front, any suggestions
This is known as the yellow light of death for the ps3 (ironic i know because it blinks a red light). This can be caused by the unit overheating causing solder on the main board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 starts to turn on for 1 second. Yellow light flashes, system shuts off, and red light blinks. Help?
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
PS3 switching itself off
Let me guess...
You get a blinking red light then it shuts off.
Your system probably overheated and unfortunately Sony has it setup so that when it happens you have to send it in for service.
Are you still under warranty?
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 at power on, light becomes white then blinks red
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Jan 24, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,466 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
