Question about Maytag Dryers
Is their a lube to be used on the idler shaft
    Scholar:
  • 86 Answers
No. If your hearing "scratching" noises there's two wheel bearings that could be bad or the felt that surrounds the drum on front and back.
Posted on Nov 16, 2009
I have a whirlpool gas dryer. One of the drum rollers keep getting shredded and breaking only after a couple of hours of use. I have now replaced both drum rollers 5 times in the last 6 weeks.
Did you lube the bearing surfaces of the new rollers with a good lube? Is the shaft surface for the bearing smooth? Do the new rollers wobble on the shaft (very bad)? Do your have the drum on straight and is it riding on the felt surface in front ok? Do the rollers turn easily after you install them or are they jammed up for some reason? What does the surface on the drum where the rollers ride look like? Does the idler pulley for the belt hold the belt steady in the correct place on the drum or does it wobble around? I have serviced these rollers on many occasions and they last a long time. The felt in front should be both in front of the drum and reach across the outer front edge of the drum. Sometimes it get all bunched up at one spot in front of the drum without wrapping around the outside too. I put the bottom in first and then use a J shaped piece of bent tin to guide it in on top where I can't see it.
Dec 12, 2015 | Whirlpool Dryers
Kenmore sewing machine keeps squeaking how to stop it?
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
Oct 23, 2015 | Kenmore Sewing Machines
I have a pulley noise don't think it is the idler is there another they have a problem with. thanks
Not quite sure where to go from here, but have you tried this:
With the engine running, lube the idler pulley shaft with WD-40 or the like. If the noise stops or subsides, you have likely found the problem. If not, you know to look elsewhere.
Best of luck.
Mar 17, 2015 | 2005 Dodge Ram 2500 Truck
Belt squeak on ford ranger 3.0
Change belt on-less the idler has to be lubed up with fluid film or white grease.......Hope this helps.
Oct 15, 2010 | 2000 Ford Ranger SuperCab
Dryer drum will not turn
Probably the belt is broken. To replace the belt you need to pop the top and remove the front then get the drum out. Check that the rollers and idler turn freely. Use quality zoomoil to lube the rollers and idler. Repair photos and more here
Aug 11, 2010 | Whirlpool LGR5636L Gas Dryer
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
Drum won't turn
Your problem could be a broken belt or a belt that has come off the motor or idler arm pulley.
Try this first:
Unplug the dryer, then reach inside and rotate the drum 1/4-1/2 turn.
Plug the dryer back in and push the start button. Sometimes this helps because a motor will get a dead zone in it and this will move it from the dead zone.
If that does not work, If you have a front loading machine:
Remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, motor, and idler arm with pulley.
While you have the drum out of the way, it is a good time to lube the drum rollers and check them for flat spots. Lube the drum rollers at the shaft with a good grade of machine oil such as 3 in One oil.
If the rollers have flat spots on the, then they will need to be replaced.
I hope this helps
Oct 04, 2009 | Whirlpool Dryers
Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Sep 07, 2009 | Maytag Dryers
The noise appears to be located at the tensioning idler wheel. I removed it and the shaft is shiny along with the wheel bearing which is a sleeve bearing. It's lubed well and not wobbly on the shaft. When...
if the belt has cracks it is wearing out and loosening up. everything is precise even though it is just plastic it matters. also make sure you use packing grease to lube it.
Apr 15, 2009 | Dryers
Vaio PCG-R505EL - fan making noise
I too removed the fan from the housing and cleaned the fan shaft with a Qtip. Then I cleaned the magnets.
THEN I used a really light bike chain lube called Prolink to lightly lube the magnets and the fan shaft.
The thinness of the lube ensures that it won't gum up the fan shaft and if the shaft does make contact with the housing it won't make quite so much noise.
Three days now and the difference from "grinding chrun" to whirring fan is noticeable.
Sep 09, 2008 | Computers & Internet
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
