Question about LG enV Touch VX11000 Cell Phone
Shortcut menu button on VX11000 is stuck in the upper left corner of the display. It does not respond to taps, and can't be moved on the display. The rest of the dsiplay operates normal. Performed a calibration on the touch screen, no help. Any ideas?
  • greekkid7 Dec 04, 2009
    Did you ever fix the problem? My phone is having the same problem.
  • Kent727 Dec 05, 2009
    No, it's still stuck in the corner. Plan on checking with Verizon but haven't done that yet.
  • LG Master
  • 8,404 Answers
Your phone may need professional adjustment. Please take your device to the professional repair shop located within most Verizon sales areas.
While there, ask them to update your software.
Thanks for posting your question at FixYa.com
Posted on Dec 13, 2009
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
Tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
Press*#0000# to display phone factory information and firmware
General Tips
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 | Cell Phones
Garmin 2720 touch the (s) and the (T) responds
You need to recalibrate the touchscreen. Try this: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Go through the entire procedure of pressing each dot as it appears on the screen.
Once completed the Nuvi will display Calibration Complete This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Feb 11, 2014 | Garmin nuvi 205 GPS Receiver
How do i change languages?. I'm stuck in Italian
  1. Open the "Impostazioni" app (Settings in Italian), denoted by the three gears icon.
  2. Tap on the "Generali" (General) tab (which shares it's icon with the settings app) to open it.
  3. Scroll down and open the "Internazionale" (International) menu.
  4. Tap on "Lingua" (Language) and select "English" from the menu.
  5. Tap the "Fine" (Done) button.
  6. Wait for the iPod to load the new language.
You will also want to disable the Italian keyboard, which can be accomplished as follows:
  1. Open the "Settings" app.
  2. Tap on the "General" tab to open it.
  3. Scroll down and open the "International" menu.
  4. Tap on "Keyboards" and tap the "Edit" button in the upper-right corner.
  5. Tap the red minus sign next to the "Italian" item, and then tap the red "Delete" button that appears.
Here's how to change languages while the iPod is set to English
  4. Tap on "Language" and select "English" from the menu.
  5. Tap the "Done" button.
Dec 27, 2010 | Apple iPod touch
Shortcut arrow on my lg env touch is stuck in upper lefthand corner, how to fix?
Click "tools and settings" Click "phone settings" click "security" enter pass code (mine was 0000?), click RESTORE DEFAULT...DO NOT CLICK RESTORE PHONE....This will erase all contacts and you will need to re-program your phone
Feb 10, 2010 | LG enV Touch VX11000 Cell Phone
Philips pronto now 5 years old --touch screen has become unresponsive. what to do?
There should be a reset button on the back or under the battery cover. if that doesn't work, then you can try to connect to the computer and reload your program. If you don't have the software you can find it at the phillips website. If you can't find the website email me the model and I'll try to find for you.
Jan 31, 2010 | Philips Televison & Video
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Button In Upper Left Corner (3 Lines)
make sure its no stuck down. try flicking it around the button.
Dec 27, 2007 | T-Mobile Sidekick II
Letters in upper left hand corner of screen
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
Sep 07, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
LG enV Touch VX11000 Cell Phone Logo
218 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
