Question about HP Officejet 5610 All-In-One InkJet Printer
How do I reset the clock. After the change to standard time it move up one hour instead of back.
    President:
  • 1,901 Answers
1. Press Setup.
2. Press 6, and then press 3.
This selects Tools and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
4. Enter the hours and minutes.
5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Posted on Nov 17, 2009
The unit seems to be working - except I cant get the time to change to Daylight time.I have no manual.
the only difference between ordinary time and daylight time is the time difference ( normally 1 hour) all you have to do is to move the time on or back 1 hour , the same as if the clock stopped and needs resetting
Feb 19, 2016 | Home
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
I have a clock that will only come up as pacific time zone time. I am in central time zone in the usa. How can I correct this as it does not allow me to input any time changes manually? I have tried...
1. press "MODE" (it will show the alarm time)
2. press "ADJUST" (this will switch the time zones)
3. when it is on the desired time zone, press "MODE" to return to the clock.
Mar 15, 2011 | Audio Players & Recorders
I need to change the atomic clock from military time to standard 12-hour format...can't find original manual...have owned the Radio Shack clock for 5 years.
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Jun 22, 2010 | SkyScan 86709 Atomic Wall Clock
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
HP Officejet 5610 All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
