The washer lid switch needs to be replaced as the spin cycle is not working. When I hold down the switch with a pencil the spin resumes and the water drains. I bought the actuator and switch but I cannot get the cabinet off the washing machine.How do I remove the cabinet? I removed the two screws from under the selector dials and flipped the panel up but I do not know how to remove the clips so I can take the cabinet off.
  • psblack Nov 20, 2009
    Great video,helped a lot. I agree w/ another poster who said it would also be helpful to see how the clips go back on. Thanks for your help.
    Brigadier General:
  • 3,513 Answers
Check this video. This demonstrates exactly how a washing machine cabinet is removed. Since its a video its the best way to see and try it with your washing machine.
http://www.youtube.com/watch?v=vogysB7XOc8&feature=related
Thanks
Posted on Nov 16, 2009
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Washing machine will not start the spin cycle. It can fill the water though. It's a Whirlpool machine
check to see lid switch is making contact... when you close lid it should push down on a switch ..try pushing this down lightly with a pencil
Oct 16, 2009 | Whirlpool LHW0050PQ Front Load Washer
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
Kenmore 70 Series Washer
The lid switch is bad . You can either replace it , or bypass it under the control panel . Try putting a pencil down into the hole on the top where the lid actuator goes into to see if it drains and spins .
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Spin cycle doens't work
Your hand probably won't depress the lid switch far enough to actuate it. Use a pencil, pen or old toothbrush handle to press the switch down and see if spin starts. If it starts, the lid actuator is likely broken or out of alignment.
Apr 09, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
