Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 series
My dryer timer keeps buzzing and voint turn off.what could it be.
  • Anonymous Mar 06, 2008
    YES HELP! Buzzer goes off at end of dry cycle... leading to insanity
    Kenmore 70 series heavy side by side
  • 240 Answers
Sounds like your push to start switch has went bad. When they short out, or cross contact the power continually shoots through it, and the buzzer contniues to make that "Were Under Attack" noise. If that doesnt seem to work, then its a small chance that the timer has went bad.
Posted on Jan 25, 2008
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Kenmore dryer problem
Good day,
Sounds very much like the motor is going bad. Very slim chance that the timer could cause that problem because of pitted contacts, but that would not explain away the noise when trying to start.
Here's a good tutorial if you want to replace the motor.
http://www.applianceaid.com/wpmotor-change.html
Apr 01, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
