Question about Kodak EasyShare M1033 Digital Camera
When I turn on my EasyShare M863, it turns off again. I have tried to change the battery, etc. But nothing has helped. I was going to send it in for help, but cannot locate an address. I received this camera as a gift in approximately May of this year.
    Scholar:
  • 78 Answers
1. Remove the batteries from the camera then clean the battery contacts
2. Remove the memory card
3. Insert the battery back on the camera in correct position
4. Place the camera in Auto Mode (auto mode is the green camera icon on the dialing mode)
5. Try to turn it ON (if still doesn't turn ON)
6. Charge the camera plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
8. Camera will charge until light turns off or (up to 3hours) then test the camera if it will turn ON
9. You can also check http://www.kodak.com/go/usbcharging
10.You can also follow the steps on this website www.kodak.com/go/stepbystep
**Contact Kodak support line 1 800 235 6325 (23KODAK)
kodak camera warranty is one year from the date of purchase or from the manufacturing date which ever is longer
Posted on Nov 16, 2009
Kodak M863 charge ok checked battery is charged and tried new battery. Within one day battery is flat.
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Oct 29, 2014 | Kodak EasyShare M863 Digital Camera
My <KODAK EASYSHARE M863 Digital Camera> won't let me upload pictures onto my computer. I have dont this several times and it still won't let me. I have plugged it into the computer via USB...
Search Google for a driver for the specific camera. Or download a copy of Kodak Easyshare. If you already have Easyshare software installed, try re-installing or updating.
Jul 22, 2011 | Kodak EasyShare M863 Digital Camera
Good-day I like to find out, please why is my Camera M863 lens is not going in anymore, trying to switch on the camera the lens goes in and come out back and the camera wouldn't work. thanks so much i will...
Hi there first of all I like to say its a common problem. Its happens when the lens guide pin damage or dislocate. Another general reason is scratch or dust on the Lens barrel or body. So please follow the steps below and let me know the result.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
I hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Mar 09, 2011 | Kodak EasyShare M863 Digital Camera
I turn the camera on and the lens thing comes out and goes right back in and the camera turns off.
To me, that usually means that the batteries are dead. I would replace/recharge them and try again.
-SJ
Mar 08, 2011 | Kodak EasyShare M863 Digital Camera
My camera will not turn on, it is fully charged. When I turn it on it goes to the main Kodak screen and then just shuts off. I have tried cleaning the battery, but nothing has worked.
There is a systems control board failure or the systems control has detected a problem in the camera. I know you have fully charged your batteries, but try regular batteries just to be sure, because as the rechargeable batteries degrade the systems controller will shut the camera down.
Jan 13, 2011 | Kodak EasyShare M863 Digital Camera
My daughter has a Kodak Easy share M863 when you turn it on it shuts off right away. Why?
this is normaly flat batterys they only like high power batterys in them
try a better set of batterys first,,, good one's!
Nov 12, 2009 | Kodak EasyShare M863 Digital Camera
Kodak M863
Clean the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Do the same to the battery and the charger.
Oct 07, 2009 | Kodak EasyShare M863 Digital Camera
My M863 Easyshare will not turn on. Battery has
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Sep 28, 2009 | Kodak EasyShare M863 Digital Camera
My lens won't close
My camera does the same thing. It is getting progressively worse. To get it to work, I have to open the battery door and push the battery a little and finally the camera will turn on and lens will close. Something is wrong with the connection at the terminals and I don't think its something that the owner can easily fix, but at least you can jump start the camera working again. Its just a pain to have to fiddle with it sometimes and it scares me that it might not start again one of these days. If its under warranty get it turned back it quickly.
Sep 12, 2009 | Kodak EasyShare M863 Digital Camera
My M863 Kodak Easyshare camera turns right off.
sounds like a power issue.maybe your batterysare no longer taking full charges
Jun 29, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
231 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
