Question about HP PSC 1350 All-In-One Thermal Printer
Keeps printing test sheet
My hp1350 all in one continues to print test sheet every time i turn my printer on. and even if it is already on and i try to print a document the test sheet comes out first. can you tell my why? and how to fix it?
  • morocco Jan 18, 2008
    thank you so much for your help . printer working fine
  • 3 Answers
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Posted on Jan 18, 2008
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Keep getting message Press Enter to Align Cartridges
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Oct 25, 2008 | HP PSC 950 All-In-One InkJet Printer
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot printĀ  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
HP PSC 1350 All-In-One Thermal Printer Logo
216 people viewed this question
Ben Johnson
