Question about Dell Latitude D410 Notebook
I'm looking for instructions on how to change my Dell D410 laptop hinges. I have the hinges, just need to figure out how to get at them!
Take a look at this link, it will show how to remove the display. It has good hints about how to do it all safely/correctly. That should get you started.
http://support.dell.com/support/edocs/systems/latd410/en/sm/display0.htm#wp1066876
Posted on Dec 18, 2009
  • bh47 Dec 18, 2009
    Caution, you might wish to have an experienced person do this. I know of one case where the screen was damaged, when the narrow frame was removed, to get access to the top half of the hinges.
  • 691 Answers
Pop the cover abover the keyboard, you then see the hinges
Posted on Nov 17, 2009
  • 94 Answers
Make sure you have a flat pliers then get a 1/2inc metallic plate preferable from a tin, cut into two hold with glue; get two strew to hold them in between to get a perfect bond.
Posted on Nov 16, 2009
Touch bad driver for dell latitude d410
Hi elsankary111,
The touchpad driver for your laptop can be downloaded from Dell's support website. Since I'm not sure which operating system your laptop has installed, I'll give you some more detailed instructions for locating the driver:
  1. Visit www.dell.com/support, and click "Support for Home Users."
  2. Click "Drivers and Downloads."
  3. Click "Select Model" and choose "Laptops," then "Latitude," then "D410."
  4. Click "Confirm."
  5. Choose your operating system (Windows XP, Vista, or 7) from the "Operating System" drop-down menu.
  6. Choose "Mouse and Keyboards" from the "Category" drop-down menu.
  7. Click "Download" next to the "GlidePoint/StickPoint" driver and follow the on-screen instructions to download and install the driver.
I hope this help you locate the driver you need. Thanks!
May 26, 2011 | Dell Latitude D410 Notebook
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
Screen hinges are lose and screen will not stay in one positiion. How do I tighten the screw?
<span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Laptop hinges cannot be tighten, and they need to be replaced.</span></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"></span></span><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Check these WEB sites on how to replace them.</span></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><b>Replacing a hinge, or both of them, isn't very tough.</b></span><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><br /><a href="http://www.insidemylaptop.com/replace-br...">http://www.insidemylaptop.com/replace-br...</a></span></span><br /><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"> <h3 style="MARGIN: 0cm 0cm 0pt">Replacing Display hinges</h3> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-ansi-language: EN-AU; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://www.laptopparts101.com/display-screen-hinges/">http://www.laptopparts101.com/display-screen-hinges/</a></span><br /></span></span>
Aug 26, 2010 | Dell Latitude D410 Notebook
HOW TO REASSEMBLING MY LAPTOP FOR DELL D410?
Here's a link to the service manual for the Dell Latitude D410:
http://support.dell.com/support/edocs/systems/latd410/en/sm/index.htm
This service manual describes in step-by-step how to disassemble/re-assemble this laptop model.
Jun 12, 2010 | Dell Latitude D410 Notebook
I have a Dell latitude D-410; the lid is loose and it barely keeps upright
Sounds like you need hinges. Its easy to change, just pull the rubber bumpers off of the screen bezel. Remove the screws that are under these bumpers usually 5. Then work your fingers around the bezel on the inside, you should hear a popping sound and the bezel will seperate as you work around. Then pull the four screws that hold the LCD in place. Finally pull the "D" screws from the bottom of the laptop and the back of the case. Then replace them.
Jun 04, 2010 | Dell Latitude D410 Notebook
Loose hinge/lid on Dell latitude D410 laptop-lid does not stay upright and falls back flat and no screws to tighten...How can you fix this? Thanks
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Jan 22, 2010 | Dell Latitude D410 Notebook
HOW CAN I GET INTERNET CONECTION IN MY LAPTOP
I assume that you have loaded all the drivers for you laptop from
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D410&os=WW1&osl=en&catid=&impid=
If you need the manual,
http://support.dell.com/support/edocs/systems/latd410/en/index.htm
The instructions for connecting to a wireless network is under the "wireless local area network" instructions.
Nov 12, 2009 | Dell Latitude D410 Notebook
THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Oct 06, 2009 | Dell Latitude D410 Notebook
Dell Latitude D410 Notebook Logo
151 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
