Question about Canon IXUS i7 Digital Camera
Zoom error on fuji digital camera?
I keep getting a zoom error on my fuji digital camera? The lens is stuck open and won't retract?? What is this telephone repair trick people talk of?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom lens won't retract
help!!
mine is the exact same way
should i just buy a new cam?
Jan 03, 2008 | Fuji FinePix F20 Digital Camera
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Canon IXUS i7 Digital Camera Logo
197 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
