Question about Toshiba Satellite A135 Notebook
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the driver HL-Dt-St DVDRAM GMA-4082N ATA Device is corrupt. I tried to update this online but found nothing.......... Could not find any file for this in my hard disc. right now I can see any drive other than C: in my computer. judy
  • 66 Answers
Backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Posted on Nov 17, 2009
5 Suggested Answers
  • 10 Answers
SOURCE: Drive for HL-DT-ST DVDRAM GMA-4082N ATA Device
First thing I would do is go to My Computer or just Computer (under Vista) and see if drive exists. If it does show up it could be dirty and needs cleaning. If this doesn't help replace the drive. If it doesn't exist, Widows didn't see the drive at all and you need to pull it out and verify connections and possibly clean the connectors on DVD player. Plug it back in and Windows should say new drive found, if it doesn't I'd replace it.
Posted on Feb 15, 2009
hardkiss69
  • 43 Answers
SOURCE: GMA 4082n device driver not working properly code 39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
pankaj_dic
  • 1250 Answers
check whether the device is detecting properly on bios or not
Posted on Oct 01, 2008
  • 144 Answers
SOURCE: HL-DT-ST DVDRAM GMA-4082N ATA DRIVE CODE 19
The driver can be downloaded from HP's website under Drivers and Support. Unfourtunatly corrupt registry entries are really hard to work with. I do not know any other way then to reinstall the software and hope for the best.
Good Luck
Posted on Jun 18, 2009
MY LAPTOP DOES NOT RECOGNIZE MY DVD/CD DRIVER... CODE 39
you need to do
1) confirm the dvd driver works ok at other same laptop or find a usb dvd drive adapter to check it works well or not, the dvd driver damage if not
2) check the dvd interface pins (no damage or disconnection) on the motherboard, there is hardware problem that you can not see or heard any lights and driving sounds when the power on
Feb 06, 2009 | Acer Aspire 5610-4648 Notebook
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Oct 01, 2008 | Computers & Internet
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
Jun 08, 2008 | Toshiba Satellite P100 Notebook
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
Asus lamborghini dvdram
Hi Rizi
You try to reinstall it using the reinstall driver tab in the properties of the hardware.
If nothing good happens then try to run system restore on your pc.
Hope it works now.
Feb 16, 2008 | Computers & Internet
no this is basic drive if this driver do not load on ur system check ur drive configuration means jumper setting if that is in master change and get it into slave any , primary or secondary.
Sep 23, 2007 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
3,378 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
