Question about Kenmore 91365 Compact Refrigerator
Everything inside are getting freeze, even in
Everything inside the refri are getting freeze, even in minimun level
  • gch219 May 11, 2010
    Yes, we are keeping the door closed tightly with a doorstop.
My maytag 12858102 is not freezing but the refri side its cold...how can I troubleshoot it
if there is frost on the back wall of the freezer then you have a defrost issue
Feb 03, 2016 | Maytag Refrigerators
DOOR LEFT OPEN ONE HOUR REFRI/FRE WON'T GET COLD
somehow may be stuck on ur defrost level cycle? u can check it by finding it usually inside the fridge at the top. a small plastic box like thingy. which if u look at it you will see a tiny whole which u can stick in a small philips screwdriver and turn slowly till u hear a clicking sound only 1 click not 2 or else u just turned on and off the defrost cycle. what you want to do is take it out of defrost cycle, so with screwdriver turn clockwise, good luck
Mar 12, 2015 | Refrigerators
My refri is working everything but is not getting cold ???
If your temperatures are higher than what you set it to be check your fans to make sure they are blowing cool air
Aug 11, 2013 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My gas golf car leak gas over the exhaust is two cycle engine.
It isn't a vw car is a golf cart (for move in the golf fields) thanks any way.
Nov 11, 2008 | 1995 Volkswagen Golf
Refri temp 60degrees
Try down behind the crisper drawers where you will find a vent opening to the lower section of the freezer. It may be blocked by ice buildup. Also check and see if there is frost buildup on the back wall of the freezer. These items can stop the air to the refrigerator and even though you may think the freezer is working O.K. it could be the source of your problem.
Jul 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Tank won't freeze
The keys are to make sure the freezer is cold enough, and to make sure the bowl is level when it is sitting in the freezer. 24 hours is usually required, despite what manual says.
If all else fails, the freezer bowls are replaceable - you can order them from Cuisinart - if you are in-warranty, they may even be able to give it to you for free.
-tha Mp3 Doctor
Jul 08, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Spin cycle
The washer needs to be leveled with a level first.If it is level than the clothes should float evenly in water.Not level everything floats to the un even side and they will bunch up.
May 23, 2008 | Maytag Performa PAV2200
Digital Tempeture numbers off
Those control boards are sort of flakey and any kind of power surge, etc. can really goof them up. If you check under the very bottom of the fridge there should be a technical sheet taped up to the underside in a plastic bag. Take that out and read it to see if there is a test reset you can do before replacing the board.
Jan 03, 2007 | LG LRBN22514 Bottom Freezer Refrigerator
Kenmore 91365 Compact Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
