Question about Microwave Ovens
When you select cooking cycle pressing the start botton the clock will count down whatever is in the oven does not heat up. HELP !!! THANKS
  • usafamily4 Nov 16, 2009
    We are happy that you responded so fast THANKS .
  • 566 Answers
If everything is running normally except that the food does`nt warm up then you can assume that in 90% of the case, your magnetron is faulty.
Now the price of a new magnetron would run around $40 to $60 depending on the model and power. If you are handy with a screwdriver you can replace it yourself, it is a pretty straightforward job, otherwise a repair shop may charge you $90 or so. If you think its worth it then your microwave should run as good as new afterward.
hope this will help Good luck
Posted on Nov 17, 2009
    Scholar:
  • 111 Answers
Sounds as though your Magnetron is not working.
This is the heating part of the microwave and in most cases is not easily accessible.
You may unplug the microwave and if you have a exhaust type microwave then there is screws either on top or in the front that allow you to remove this section, and once removed you can remove the screw on top of the controller, which gives you access to the fuse and fan and electric components inside.
Make sure noting is melted and smell to make sure nothing smells burnt.
In most cases, if it is the Magnetron then between labor and parts you almost better off to purchase a new microwave.
Good Luck!
Posted on Nov 16, 2009
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Will only defrost, and not cook on high
What is the make and model number?
Eric
Jun 21, 2009 | Microwave Ovens
Microwave lights up but no cook!
Magnetron of your Microwave oven may be defective. If there is a fuse between the highvoltage transformer and to the highvoltahe capacitor check the fuse is blown off. If so replace the fuse. If it is Ok change the Magnetron.
May 06, 2009 | Microwave Ovens
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
