Question about Oreck XL Ultra Bagged Upright Vacuum
No power when i flip the start switch to I or II? Is there a reset button?
  • spigeon Nov 17, 2009
    fixed it
  • 85 Answers
No there is not a reset. Take the screws out of the handle and inspect the wiring most likely the switch is bad and it is very easy to replace.
Posted on Dec 16, 2009
Take off the botton with a phillips head screw driver, and, while the cleaner is unplugged, check the connections on the right side of the motor as you look at the vacuum cleaner from the front. They may be loose and you may need to crimp them a bit.
Posted on Jul 19, 2012
Will not start
First check the reset button on the back
Mar 10, 2014 | Riccar Vacuums
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
I sucked up a sock into the carpet attachment of my electrolux 3500 series and the carpet attachment cut off. After the sock was easily removed (it was only wrapped around the brush part) I reattached the...
Did you press the reset button? There will be a reset button either on the back of the unit just below the bulkhead or on the top side of the base.
Locate the reset button and press; this should allow the carpet attachment to resume operation.
If you require an Owner's Manual try downloading the Epic 3500 manual from this site:
http://www.aerusvacuums.com/support/manuals/index.cfm
May 01, 2011 | Electrolux Epic 3500 Vacuum
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
I by accident sucked up the corner of a sheet into the powermate of my vacuum. I turned the vacuum off and pulled out the sheet but now the powermate is no longer working (suction works fine) Is this...
These power heads have a kill switch on them. Not exactly clearly labeled.
the kill switch reset button should be on the right side of the unit as you look down like you are using it. you may want to try pushing it with the power to the power brush on. Upon resetting the button there, the power
head should start no problem.
Good luck with that.
Mark
Nov 12, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Where is the reset button located?
Greetings from GoVacuum,
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
Jan 15, 2010 | Riccar 8850 Vacuum
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
May 25, 2009 | Rainbow 75th Anniversary Canister Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
764 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
