Question about Canon Cameras
Memory card error - After taking about 300 pictures on a 2 Gig Kodak SD memory card. I get a message on my Canon camera that says '' memory card error'' I tried to put the chip in a differant camera but it tells me to '' Format The Card'' I am afraid if I do that I will loose all of my pictures. I tried to load the pictures into my computer the way I always do and nothing happens. Any helpful ideas ? Thank You
  • Canon Master
  • 4,738 Answers
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're inexpensive.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but the file structure will eventually corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again. Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Posted on Nov 17, 2009
I just got a kodak slice 14 megapixle.. with out a memory card it only takes about 20 pictures.. where is or how do I find out the internal memory,... It looks like even if I use a 4 gig micro card. the...
Depends on the size of the images - if you are using best quality and large size, the number of images will decrease accordingly. Look in the manual for the correlation. BTW, the internal memory and the SD card are not the same thing.
Jul 09, 2017 | Kodak SLICE Touchscreen 14MP Digital...
My internal memory is full, or so says the message, but there is nothing IN my internal memory. Help! It will not take pictures.
buy an sd micro memory card and use the external memory instead .. camera internal mems are only made to hold around ten pictures were as an 2 gig mem card will hold around 2000 pics and there very cheap about $ 25
Dec 07, 2010 | Kodak EasyShare M863 Digital Camera
I have replaced the battery and memory card, the camera keeps saying I need to format the card, but then it says it is formatting, then gives another message saying the card needs to be formatted....
If the memory card replacement is an SDHC model card the Kodak z740 will not work with it. The memory card has to be a standard SD card of 2 gig size or less to properly function. Take card out and turn on camera. See if you get same error. You should get missing card error but otherwise be able to operate camera controls such as zoom, flash, etc. If that is fine find old card you used and place back in camera... or purchase a standard SD card from Walmart for 10 dollars
Jun 11, 2010 | Kodak EasyShare Z740 Digital Camera
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Jan 20, 2010 | Cameras
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
On a kodak c33o camera i get error code e 00100 when i try to format memory card
Hi there.
If the SD card is over 1GB then the camera does not support it.
The Kodak Website States that your Camera does NOT Support 2 Gig SD Cards...
However, there is a Firmware Upgrade Located at the Link Below that is said to Help Resolve this Issue...
Kodak Firmware Upgrade Page...
Thanks for choosing FixYa!!
Jun 09, 2009 | Kodak EasyShare C330 Digital Camera
Memory card
Did you just buy this card or have you had it working for a while and now this is happening?
From everything i have read about your camera, they won't take a 2 Gig card. A 1 GIG card is the biggest that is compatible with this camera. If the card is new i would take it back to the store and see if they will let you exchange it for a 1 GIG card.
If this just started happening after using it for a while -- it could be a problem with the card or the camera. Try putting in a different card and see if it will let you format that one. If it does you know for sure the problem is with the card. If you keep getting the same message no matter what card you use, i would phone Kodak. But, according to Kodaks own site, 1 GIG is the biggest card that is compatible. Sorry I couldn't be more help.
Good Luck.
May 12, 2008 | Kodak EasyShare C315 Digital Camera
Cameras Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
