Question about Vocopro VHF-35 Professional Microphone
THE PLUG TO MY WIRELESS MIC SYSTEM THE WIRE IS BAD WHERE IT PLUGS INTO THE WALL DO THEY SELL REPLACEMENT TRANSFORMER / PLUG MODEL # HKD135-500
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
My transformer on my new polar express does not work what am i doing wrong
No power to the transformer or to the track?
If not to the track, make sure you have the correct wire connections made from the transformer to track.
If no power to the transformer from the wall plug,
sounds like the cord needs replacement.
Dec 19, 2012 | Lionel The Polar Express Train Set
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
My router will not power on after a power outage. Is this something that can be fixed?
Test the transformer with a volt meter, should get +5 volts on the center of the plug. If not, purchase a 5 volt 2.8 amp. transformer that will plug into the router. A good tech could splice the plugs if you can't find a transformer that will plug into the router.
If the transformer is good, then the router is bad. Ebay or purchase a newer model.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
No power to my router
Check the wall outlet for power, using a lamp or such. If you can get a multi-meter, set the meter to Volts-DC between 12 and 20. Plug the power supply into the wall outlet and test the other end for voltage. The power supply should tell you its output so the reading should be more than a couple of volts. If it is less or ZERO the power supply is dead. If it has power, then open the router and check for a fuse. If the fuse is dead, replace. If there is no fuse or the fuse is OK then the router may be dead. Best of luck.
May 29, 2009 | Linksys Wireless-G Broadband Router
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
My thermostat has no power. the wires to it has no power. The fuses on the heater chip board are okay. What else can I do? Where can I locate the transformer to the A/C/Heater?
in the control box to your furnace or air handler, there should be a transformer near by.be careful though, it has high voltage going to it though.just follow the high volt wires, the large ones,from the wall plug to the machine, into the control box to the transformer or the fuse chip board.the big black wire will go to terminal L1 at the board and the white wire will go to nuetral at the board.unplug your wall cord first so you won't get shocked. it is hard to see into the control box and board connections.also, plug a light or lamp into he wall socket to see if you have 110volts to the plug.
do that for a split system.an airhandler wont have a wall socket.it will have a disconnect box with fuses in it.it is also 240volts so be carefull.
Dec 29, 2008 | Amana Heating & Cooling
Will not power up, need replacement wall plug
Radio Shack can hook you up. Take your old transformer to them and they will help you out.
Jul 09, 2008 | Wave Industries OLY-OL3000 Globe Phone
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Vocopro VHF-35 Professional Microphone Logo
55 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
