Stops after agitation cycle
I have a Kenmore 70 Series washer that I am having issues with.
In Delicate, Regular and Heavy Duty mode's the washer will, fill with water
and complete the agitation cycle. No abnormal sounds and all works fine up until this point.
Lately, which seems to be happening on a more regular basis now, the washer does not drain between the agitation cycle and rinse cycle. If I manually change the setting (by spinning the dial though all the cycles) and set it to rinse, the washer will drain and the rinse cycle will run. After the rinse cycle I have to manually spin the dial through all the cycles as I did earlier with the rinse cycle and select spin. However in this case the water drains but the spin cycle does not start until after I manually spin the dial and set it to spin again. Just as an fyi...there no abnormal noises when the washer spins.
I also did check the switch on the lid and do hear the click that was described in other postings.
Thanks in advance
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the washer will agitate correctly.
This points to one of two possible problems.
The first (and more expensive) is the timer with an intermittent problem.
The second is what is known as the Neutral Drain Assembly.
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had basically the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle or in your case, re-setting the cycle.
Apparently, by opening and closing the lid, or re-setting the cycle, torque from the motor starting throws the cams into the right gears so that the washer will spin..
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
See the Whirlpool / Kenmore Service Manual for these washers. It has a very good section on the transmission and neutral drain assembly as well as a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators and the drive block spanner nut.
The top agitator uses a plastic 1/2" drive bolt. I've used a 1/2" extension for a socket set.
Rather than buying a special spanner wrench (about $20) I used a short 10" pipe wrench ($9 and also used for cracking walnuts) )hooked over one of the tabs on the spanner nut and tapping the handle of the wrench with a hammer.
You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Nov 16, 2009
    Scholar:
  • 86 Answers
I assume this is a top loader. Your timer's bad. Not hard at all to replace.
    Sergeant:
    Champion:
  • 289 Answers
Your timer is bad.the point's that put power to the timer motor are not working.so it will not complet the cycle.at this point you have to make the call. do i pay for the part, or do i buy a nother unit.
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
We have a Kenmore 80 series washer that stops in mid-cycle when using the normal/regular option. It stops before the rinse cycle. However, it rarely does the same when using the heavy duty and delicate...
1. This is an issue is usually associated with the timer. Symptoms you describe are a malfunctioning timer and it needs replacement. If this is a timer that is software based the firmware module will have to be replaced. You will have to call your local appliance repairman or if you can do it yourself it will require the schematic and the service manual to disassemble and reassemble the module or electronic timer circuit.
Mar 10, 2010 | Washing Machines
Kenmore 70 series 110 washer won't drain or spin, but agitates
You have a broken lid switch. Check to see if the switch is broken off of the two screws that hold it under the lid. If it is, get a new one, take off the case and replace old switch with the new one.
Apr 06, 2009 | Kenmore 24932 Top Load Washer
Kenmore 90 Series only agitates on heavy-duty cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
