Question about Coffee Makers & Espresso Machines
Help... Silvia is sick!
I have a sinking feeling. My Silvia makes marvellous steam for milk, but on Saturday it ceased producing hot water. I live in Nth Tas. What is in store for me in resuming superb production? Anne
  • 5,568 Answers
In every coffee-maker is at least one 'thermal fuse.' Since these are now made almost exclusively in China, the variability has become a real problem and they often fail without ever having reached the design temperature of the part. Further, because of where they are installed, they are welded instead of soldered and therefore not easily replaced. Sorry to be the bearer of bad news-
Posted on Nov 16, 2009
What's wrong with my machine? Espresso is fine, but no steam.
Agree with previous suggestion. The steam pipe is most likely blocked and generally the blockage occurs in the bend of the steam pipe. Either try removing the wand and clearing it or use a thin piece of wire/pipe cleaner and insert it up the pipe. It could alternatively be a piece of limescale blocking it so it may be worthwhile to try descaling the machine if after clearing blockage. Hope this helps.
May 01, 2014 | Rancilio Silvia Espresso Machine
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Hi, I have an 8 year old Silvia...cleaned often, only use purified water in it. Recently, it has not been able to reach steam temperature. I end up with watery milk, as the steam wand is producing s
It is possible that the thermostat for the steam is not operating or need to be reset. There are 3 in the silvia machine. Remove the four screws on the top to gain access. Unplug machine before doing any maintenance first.
Mar 18, 2014 | Rancilio Coffee Makers & Espresso Machines
Sylvia still makes great milk for steam but on Saturday it stopped producing hot water for expresso. What do I do? I live in North Tas
Hi
. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Nov 15, 2009 | Rancilio Silvia Espresso Machine
Steamer will not work
Make sure your milk frother is not blocked.
Aug 14, 2008 | Gaggia Titanium Espresso Machine
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
