My frigidaire washer won't spin? - Computers & Internet
  • jgonz720 May 11, 2010
    Does it drain? Agitate? More details please.
  • hondo73162
    hondo73162 May 11, 2010
    Do you have a Model Number ??
  • 68 Answers
Will it drain? If something is stuck in the pump and it won't drain, then it won't spin.
Posted on Nov 16, 2009
How can I use jumpers to test 131763202 Frigidaire door lock switch on washer? Won't agitate or spin.
Hi slogjlog - Often when a unit does not spin or agitate, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
Washer won't spin on spin cycle but spins during other cyles
Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front loader washer won't go into spin cycle after the clothes are washed
Sounds like you need a technician to diagnose the timer of the unit. Also the sensor that communicates to the timer.
Aug 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin The washer is a frigidaire front loader model LTF2140E53. will cycle through all settings, but will not spin. Cycle ends with clothes soaked.
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Won´t spin at all in any cycle
Goto http://www.frigidaire.com/manuals and download the model wiring diagram. It will explain how to view and interpret additional error codes. I have the exact same issue with my machine (will not spin). The error code #E47 indicates that the machine thinks the door is open and will not engage spin. Fixes: new door switch ($85) or new control board ($285).
Aug 05, 2009 | Frigidaire ATF6000ES Front Load Washer
FRONT LOAD WASHER WON`T SPIN DRY AT END OF CYCLE
CLEAN OUT PUMP IS THERE WATER STILL IN THE MACHINE ,, OR WIERD NOISE ??????????
Nov 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Computers & Internet Logo
David Payne
David Payne
