Question about Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD
I tried to remove adjustment caps from my scope to zero and the entire adjustment assemblies unscrewed.i can not remove cap.
    President:
  • 2,702 Answers
This is what happens when there done up to tight,
get a soft jaw vice and put the thred of the turret into the SOFT JAW VICE!!! (lined with leather),,,,
very gently grip the threds and undo the cap,,,
when refitting the bottom bit to the scope put a small blob of grees on the bearing part,,,oh,,by the way!!,,,
it should be regased! or it could fog up on you when it gets cold,,, only just nip up the turret caps next time
Posted on Nov 16, 2009
How do you remove the suction inlet and install. A
Fuel cap ... oil cap ... dust cap ...?
Dec 11, 2017 | Cars & Trucks
How to change my battery on a 4x16x40 centerpoint scope
remove the battery cap, replace the battery, reinstall the cap.
Nov 27, 2013 | Centerpoint Technologies CenterPoint...
I have a tasco 3x9x50 world class rifle scope. The scope caps are stuck to the adjustment screws in top and side of scope. I am unable to unscrew the caps without unscrewing the adjustments as well. The...
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
Jan 20, 2011 | Tasco 3-9x40 World Class Riflescope 30/30...
Where can I get replacement caps for the elevation adjustments.
the only way to find cheap caps it try a fuw gun shops to see it they have any old scope that dont work and buy the caps that will fit your scope most gun shops keep old broken scopes just for that?
Nov 27, 2010 | Burris 3-9x50mm Fullfield II Rifle Scope...
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
How do you take off the Pannarello steam attachment to install the Cappuccinatore? Does it screw off or does the entire unit pull off. I've tried some force but I don't want to break the Pannarello. Thanks
Hi
Most pannarello's have a screw cap on top. The outer shell pulls off with a twist. Hold the inner stem and twist the cap on top to unscrew. Leave the cap and seals on the wand, or just loosen the cap and pull the whole assembly off complete, or you could loose parts that are inside.
Oct 24, 2009 | Gaggia Titanium Espresso Machine
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Caps will not screw off to adjust sights on scope
Many cap threads are reverse. try unscrewing the other direction. If this doesnt work my suggestion is to use physics to get it off.
Image a jar that is 1 litre with a lid that is 10 cm across. it takes x amount of force to unscrew that jar.
Now if that same jar has a lid that is 25 cm across there is a power advantage and a speed reduction.
Now to apply this to your thread caps. try adding layers of tape/cloth onto the thread caps to make it easier to unscrew.
Dec 07, 2008 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Lost caps
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Oct 16, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Tasco 3-9x40 World Class Riflescope 30/30 Reticle scope Clam Pack WC3940MD Logo
365 people viewed this question
Top Tasco Optics Experts
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
